I have to agree with Mark. The only reason I bought the HPHC screen was to pair it with my less than ideal lumen outputting projector, the Marantz VP-11S1. There are some negatives to the material that are obvious. There is a slight grainy look to the image. I'm not sure if that's attributed to the material itself or if the higher gain is to blame. Then there is the retro reflective nature of the screen that can be a pain to deal with. The half gain is also very low, but to be expected with this high of a gain at only 25-30 degrees. On top of that I and a few others seem to be having an issue seeing the texture in spots on the screen.
I don't hate the material as it does what its supposed to. Unfortunately there are a couple drawbacks that most people can deal with. I think Mark just wants people to stop praising this material as "perfect" or "without flaw" and that's totally understandable.
Mark, what material (1.1 to 1.5 gain) would you recommend that has what you would call a "looking through a window" attribute? I want something with a slightly high gain that looks completely "smooth" so all you see is the content. I've heard a lot of good things about StudioTek 1.3 material. Is that something you'd recommend? Or are there any cheaper solutions, maybe something like a Carada screen, that has this trait?
Edited by Seegs108 - 1/6/13 at 7:16pm
