AVS › AVS Forum › Video Components › Home Theater Computers › Help Media Browser unable to launch
post #1 of 6
It was working perfectly this morning. Now all of a sudden, It is saying it is unable to lunch and asks me If I want to disable application. I have unistalled and reinstalled it twice. I also deleted all the cache etc. Can someone please help me with this. What's the problem and whats the fix?
post #2 of 6
Install them remove it with Revo uninstaller on aggressive setting.
Make sure Revo removes the program data folder and registry key
post #3 of 6
How did you glean all that out of the original post lol - you 'The Mentalist' in your spare time wink.gif
post #4 of 6
post #5 of 6
I have just started having a problem with MPC-HC launching a .mkv out of media browser. The MPC-HC logo shows but then the screen goes grey and the movie does not play. So, please post you results with the Revo uninstaller.
MPC-HC works fine on its own.
post #6 of 6
Thanks, i cleared the cache and eliminated all the plugins and it open right up.
