Originally Posted by
kitjv
I want to connect a laptop to a Panasonic Viera plasma TV for a slideshow presentation. My laptop (MacBook Pro) is connected with a DVI-HDMI cable. The video plays fine; but no audio. Question: Can a DVI-HDMI cable transfer an audio signal?
Thank you.
It would be helpful if you'd provide the model number of your particular Panasonic, but if you check your owner's manual there should be instructions on getting audio from a DVI source connected to an HDMI input. On my GT50, i'd have to connect an audio cable from the laptop's headphone/speaker jack output to the analog audio input on my TV's Component/Composite Video input, then go into the audio menu and associate audio on that HDMI input to the Component/Composite Video input. Hopefully your TV has the same method available.
