AVS › AVS Forum › Audio › Speakers › What wires would should I look for for Monitor series II speakers??
post #1 of 6
i have not opened my polk monitor60, cs1, monitor30 and a psw505 sub so im wondering if anyone can point me in the right direction on the type of wires they use.
ill hopefully getting the denon 2113ci receiver also.
a link to what i basically would need would be great.
Thanks again.
post #2 of 6
Probably inexpensive 18ga wire, because that's all they need. Why does what they use inside matter?
post #3 of 6
You just need a single RCA coaxial cable to go from the receiver sub output jack to the subwoofer line input jack.
For speaker wire, I would suggest that you look at the MonoPrice #2791 14-gauge speaker wire, which is $25 for a 100-foot spool.
post #4 of 6
12 gauge would be too big right? go with 14 or 16 or 18?
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=9436&seq=1&format=2
would these plugs work?
post #5 of 6
For sound : There's no such thing as "too big"... there's only "bigger than needed". A "too big" wire works just fine.
For fitting into your banana jack... the ones linked say they will take 12ga.
post #6 of 6
Use this to calculate the required gauge:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Plugs are an unnecessary expense. Use them if you wish.
  Back to Forum: Speakers
