AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Toshiba 55L7200U not HDCP compliant
post #1 of 4
So I just picked up one of these HDTV's only to find out that I am unable to watch blu ray on it because it is not HDCP compliant. I was able to watch blu-rays in the past with my 42 inch LG.
Is there any way to get around this? I did a little research and came across some HDCP strippers, but they sound a little expensive. Just wanted to see if there was another way to bypass this.
BTW, I am using this with my HTPC and have an LG blu-ray/hd dvd rom drive in it.
Forgot to mention, I am using PowerDVD from CyberLink
Edited by spacegoast - 12/13/12 at 4:03pm
post #2 of 4
Specs here say that it is:
http://reviews.cnet.com/flat-panel-tvs/toshiba-55l7200u/4507-6482_7-35118537.html
post #3 of 4
Ya, I did some more research and I came across that page too. But for some reason I still cant play blu rays through my LG blu ray player...
On a side note, I am using a DVI to HDMI cable. Going to try full HDMI cable now.
post #4 of 4
Guess it was the cable, because it is working now.
