AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Pioneer ELITE Pro-101FD Still Worth It?
post #1 of 13
So, I'm looking at buying a new TV, and while browsing i came across what looks to be a solid deal on a 50" Pioneer Elite (101FD). I'm just wondering if the pioneer is a good buy at $1000 (brand new), and if there is any TV currently on the market that would have better PQ than this model, since it is getting a bit old now. I'm hearing good things about the Panasonic plasmas, and if they're better than the Kuro then I would gladly shell out the extra cash to buy that.
post #2 of 13
Yes. If 50" is large enough for you, then buy it. I would.
post #3 of 13
If you can go a few hundred more you can probably find a used 111fd and get 9g blacks and pic quality. Are you saying the tv is new?
Edited by Glashub - 12/13/12 at 5:26pm
post #4 of 13
Wow! If someone is selling a brand new 101 for a grand, I would not hesitate at all if it looks like a legit deal.
post #5 of 13
Hmm, I was under the impression that the 111FD was the same TV with speakers, a stand, and some other features... is the PQ really that much better that I should look for one of those -- and a few hundred dollars more, where??? And yes, brand new in box.
Also, yes the deal is legit, this is from an authorized dealer
post #6 of 13
BEST TV EVER MADE.
Half the black level of the 111FD
BUY IT
post #7 of 13
Go for it or someone else will! The pro 101 and the krp 500m are the identical in performance and the two best displays pioneer released to the market.
post #8 of 13
Right, its settled then, I'll try and pick this up tomorrow biggrin.gif. Thanks for the input guys
post #9 of 13
Great choice! Post impressions once you get it set up and running.
post #10 of 13
Ah, you're right. I was thinking the 101 was the 8g. I have the 111fd...maybe the best tv ever made for picture quality.
post #11 of 13
Where are you buying the TV from? Are there more? I would love a 101 or 500m.
post #12 of 13
me 2
post #13 of 13
yes, do tell where you are getting this TV, i am close to buying a used 950HD, but willing to shell out some extra bucks on this set.
thanks
