AVS › AVS Forum › Display Devices › Display Calibration › Chad B's custom test patterns
Chad B's custom test patterns - Page 3
post #61 of 165
Yes, that is good for PN-D series.
Just be careful not to get in a vicious cycle between the brightness control and interval 1 of the 10 pt adjustment.
post #62 of 165
Can you explain this better , what do you mean exactly? Please give an example.
post #63 of 165
If you raise, or lower the values of interval 1, in the 10pt adjustment. You have to go back and adjust the brightness...in some cases. I've dealt with this on my own Samsung. I try and leave 10% alone, or do very minimal adjustment. Otherwise you'll have to keep going back and forth between adjustments. I think this is what Chad is talking about. If not, Chad, please correct me.
post #64 of 165
I understand the idea of using a 4% pattern to avoid having the ABL circuit from affecting your gamma readings but does it do anything for color?
I think I may have figured out my own answer. Color patterns include lumanance which is basically how bright a color is. If you're you're using 100% intensity patterns, you run a chance of having the ABL circuit dim the pattern causing you to compensate by increasing the lumanace element of the color being adjusted. Therefore, you overcorrect and wind up with cartoonish color.
Am I even close?
Edited by JimP - 2/14/13 at 4:49am
post #65 of 165
Am I even close?
I think this is why when calibrating colour you generally use 75 or 50% lum patterns.
Personally, i try to only use the CMS to ensure i hit the correct gamut points, then revert to saturation patterns to dial the colours in, usually with a compromise. Then final check with colour checker patterns to minimise the dE. Ive been using really small 1% patterns recently with really good looking results, but im gonna try APL patterns with a constant background between 20-30% when i get a few hours spare.
post #66 of 165
For the samsung d series of plasmas it is generally recommended to use 75% amplitude /75%s saturation patterns to calibrate color with . With these patterns 100 % saturation will be over saturated but most of the colors on programming material never reach that point it's better to compromise and calbrate to 75/75 which will make your gamut track better at 50% and 25% saturation as apposed to using 75%amplitude/100% saturation.
post #67 of 165
I cant recall what method i used on my D8000 plasma, but on my Panasonic the method i described above works well although the 100% wlill be off given the focus is on the 25-75% range. Using the colour checker patterns as a final check is a great way to confirm how youve done.
post #68 of 165
Chad, are these patterns 0-255 or 16-235 levels? Reason I ask is the brightness pattern does not agree with with the dpg2000 brightness pattern nor does it agree with the 709 from BR. I have not tried to display you pattern using a thumb drive and the BR player.. will see if that makes any difference. The DPG2000 is really flaky with output levels so it would not surprise me if the player was the problem.
post #69 of 165
They are done at video levels: 16-235. The WTW bar in the Contrast pattern is at 245. Going by what I remember with my older DPG models, I believe you would want to set the DPG-2000 to RGB Full, but I don't have your model DPG.
post #70 of 165
RGB High is the correct setting for the DPG-2000. The patterns in the DPG-2000 have matched the disks and generators I have compared it to. The only exception to this I have found is when the DPG-2000 is connected to an iScan Duo. Then the patterns are off but I have not checked out why.
post #71 of 165
That is how I have it set. I will do some more comparisons tomorrow night when the wife is out. I wish Spectracal would get the known level issue with the DPG fixed as I do not trust it at all now.
post #72 of 165
Have you tried Chad B's patterns? how is it compare to your 1 % patterns? Visually.
post #73 of 165
I like the sharpness pattern on this set of custom patterns since it offers black single pixel lines with gray backgrounds to make EE easily visible (white halo around the black lines). However, if I use this pattern and display it as a PNG on my PS3's XMB (main menu), will that give me the same results as MP4 video on the PS3's XMB or better yet AVCHD format burned to a DVD?
The XMB is RGB only while AVCHD video is played in YCbCr 4:4:4 on the PS3 (just like a BD).
post #74 of 165
Just wondering if someone who owns the appropriate software could possibly build an AVCHD ISO image with a simple menu for these patterns, it would be much appreciated. Or post links to the needed freeware and instructions and I would be happy to do it.
post #75 of 165
I've done just that. It's 220mb in size. If you have somewhere to upload it, I'll send it. I used multiAVCHD to author it.
post #76 of 165
Could you put in zip so we can get it,if you dont mind.I would like a avchd version as well.Thanks Vega509.
post #77 of 165
I will set something up tomorrow and PM you when it is ready. After I get it, I will put it on my webservers and post a link so it can be pulled down by whomever wants it.
post #78 of 165
Vega509, you have a PM!
post #79 of 165
the upload is complete, let me know if you have any problems.
post #80 of 165
How about posting a link?
post #81 of 165
Hey Chad, can you post this link on the first post of this thread as well so it does not get lost.
LINK TO AVCHD ISO image of Chad's Patterns thanks to Vega509
Edited by airscapes - 3/14/13 at 10:31am
post #82 of 165
I do not have a web server available, Doug said in a previous post he will post a link once he has confirmed the iso works.
post #83 of 165
I made 75% sat / 75% level APL gamut patterns. Along with other displays, they should be useful for Mits DLP RPTVs, some of which have an undefeatable dynamic iris.
aplReducedSaturation.zip 105k .zip file
post #84 of 165
HA! Just posted the link to the ISO up a couple of posts and Chad just posted more patterns! Tony you think you can update the ISO and let me know so you can upload the new one?
Thanks so much everyone!
post #85 of 165
Might want to wait just a bit... I'll make some reduced saturation non-APL windows.
Done. First post is updated.
Edited by Chad B - 3/14/13 at 10:53am
post #86 of 165
DrFaxe had posted these patterns in mp4 format which is what I used to create the avchd disc. The png patterns changed somehow when I tried to create the disc. If Chad or DrFaxe can post the files in mp4 format I will re-author the disc with the new patterns.
post #87 of 165
Can game mode ever be calibrated correctly?
post #88 of 165
Depends on the TV. Sharps like the 632U can, but only if done in the service menu, which is no simple task.
post #89 of 165
Would a GT50 have the ability to be calibrated correctly? I've always wanted a calibration done but would find it pointless to doing I couldn't get it done in game mode as well. I'm a huge gamer.
post #90 of 165
I just burned the iso,are you saying the levels are off and the said iso is not proper for calibration?
