This is my friend's television set. Information on this set is somewhat scarce as it is a very late model - 2006ish. Seems a few people might be having this problem from what I can tell online. The TV just turns off right after turning on. It stays for about 15 seconds, the screen changes to AUX, and then blips out. It can switch over to the built in DVD player mode but then the same thing happens. The internal fuse seems okay. I think its a power supply problem. Where should I start? (yes, I know this high voltage and to be extremely careful)
AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › Philips CRT TV Keeps Turning Off - 27PC4326/37
