AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › How can I stream Amazon Prime VOD in 1080p and 5.1?
post #1 of 4
I'm aware that Hulu and/or Vudu are fine, but I have a large Amazon VOD Library and lots of freebies as a Prime member. My BD player only supports Netflix, Vudu and something called "FilmFresh(?)"
My router is close enough to be hardwired to my periphials, but I don't know much about HTPC. Could I possibly run direct from my PC or the external hard drive, or is there another way I'm missing? If I need a set-top box of some kind, such as Roku, etc. - which, if any - would run the Amazon in 1080p and 5.1? FWIW - I don't play any video games, so Playstation is not an option unless as a last resort.
My equipment is as follows:
Panasonic PT AE-7000 projector
Pioneer VSX-60 AVR
Oppo BD-103
Netgear N750 WNDR4000 dual-band router
My laptop is a current, loaded up HP, and as I said - anything can easily be hard-wired to the router.
Any help or links would be appreciated. Thanks in advance.
Rich
post #2 of 4
if your laptop has an HDMI out on it you can just plug that straight into your projector or receiver and get a little wireless keyboard/trackpad remote like this:
http://www.amazon.com/gp/product/B003UE52ME/ref=oh_details_o01_s00_i00
I have one of these and have a desktop computer hooked directly up to my TV. it works great.
post #3 of 4
Also, for Amazon VOD on PC, the plugin for XBMC works very well. This allows you to browse, search and play with a remote control rather than a KB/mouse and is free!
post #4 of 4
Amazon Vod Streams, including prime are 720p
Tivo will play back amazon vod content in 1080p/24 (no prime) but it must download to the device first.
