Hi,
I just ordered 4 of these for a friend with budget, as well as a wife who wants the speakers to be small. He will be using these for L/R/SR/SL.
Here is a link:
http://www.amazon.com/dp/B0044UHVOK/ref=pe_175190_21431760_3p_M3T1_ST1_dp_1
I have heard really good things about them. The problem is, they are discontinued, and the matching center channel cannot be found anywhere. Now i know it is recommended to match the center with the fronts, but I probably won't be able to do it in this case. What do i need to do to find a center channel that will work well with these speakers? Any recommendations?
Here is a link:
