AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Vizio color issue
Vizio color issue
post #1 of 2
Hi All,
Have a bit of a puzzle here.
I have a Vizio VX37L that the color is off on – the best I can describe it is that lighter colors have bright spots towards the center of the area of color. This happens using a cable box (Xfinity / Motorola RNG200N).
I’ve tried:
“Reset All Settings”
Change to different HDMI cable
Change to different HDMI input
Change to Component input
None of this has changed the issue
If I connect the cable box to another TV via the same HDMI cable, it looks fine.
However, the weird part is that if I connect a Bluray player (same HDMI cable, same HDMI input) to the Vizio, it looks fine.
I’m at a loss for what my next step would be – any ideas?
Jeff
post #2 of 2
Originally Posted by MrBiggles View Post
Hi All,
I’ve tried:
Jeff
Have you looked at the settings of the cable box? Does it run at the same resolution on the other TV?
Michael
