Hi!
The purpose of this Poll is to see just how much of a problem there is with the new 5020/6020 Projectors, and to get that information to Epson. Please, please fill out the poll even if you have a perfect PJ, or even if you returned your 5020/6020. It is very important to hear from satisfied owners as well as those who gave up.
If you're not sure how your PJ is, I'll post some test patterns here shortly that you can use to check.
CA = Chromatic aberation.
If you're unsure, post up your question and we'll try and sort it out.
I will be contacting Epson with the results from this poll in an attempt to make sure we can get good copies of these projectors. Or, if enough people respond positively we'll know that some of us are just unlucky. (I've been through three bad ones in a row.)
Please check all answers that apply to you.
OOPS! Under the 5020 section, it asks if you've returned your 6020. My mistake. 5020 owners go ahead and assume it says "5020". It won't let me change it.
Thanks!!!
Here's some pics to check convergence with:
Convergence_SinglePixel 1920 x 1080.zip 178k .zip file
Edited by Kirnak - 12/18/12 at 10:49am
Thanks!!!
shall I cancel my order? Can I return it for refund if it has convergence issues?
