AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › HTPC Gaming › SAPPHIRE Vapor-X 100351VXSR Radeon HD 7970 run three monitors? NOT at the same time
post #1 of 5
I am building a new HTPC that will also be my daily work computer. I know this is the gaming area, but didn't know where else to post.
The computer/HPTC will NOT be used for gaming.
Silverstone CW02 case
ASUS Rampage IV Extreme LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard (if it fits)
Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor
G.SKILL Ripjaws Z Series 64GB (8 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) RAM
and for the video card, I am looking at;
SAPPHIRE Vapor-X 100351VXSR Radeon HD 7970 GHz Edition 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Will this GPU run three monitors? Two 27" desktop monitors for work and One through a Marantz SR7007 AVR to a JVC X30 projector - NOT all at the same time.
From the GPU I would like to;
Use the HDMI out to the AVR - running the audio and video for the projector
Use the two DVI outs with two 50ft HDMI to DVI Adapter Cable to the 27" monitors HDMI inputs
Or I may just use standard HDMI cables with DVI to HDMI converters
Will this setup work? I am not planning on running all three outputs at the same time, either the two desktop monitors or just the projector.
Thanks, Eric.
post #2 of 5
Yes.
The only thing you need to look at is the ability to run the 2 27" monitors at the same time, I'm assuming both at once. Since you won't run all 3 in tandem.
But why do you need this particular card if you aren't going to game? It seems like a heaping helping of overkill. For an HTPC, there's no reason to spend over $150 for a video card.
OK now that I look at the rest of your gear, what the heck do you do for work? Because that's a lot of PC going in there.
Edited by Yrd - 12/15/12 at 11:55pm
post #3 of 5
Originally Posted by Yrd View Post
Yes.
Yes, definately the two desktop monitors at the same time.
If I end up adding a third desktop monitor, would I need a second card?
But why do you need this particular card if you aren't going to game? It seems like a heaping helping of overkill. For an HTPC, there's no reason to spend over $150 for a video card....
I do analysis and design work, the software is a lot more expensive than the computer running it. I build the computers to last about 18 months to 2 years.
When you say that a HPTC doesnt need anything more that a $150 video card, what parameters are you basing that on? as I really dont know that much about video cards -- What I do know is that with the software that I run, the more RAM the better.
Thanks for any help, Eric.
post #4 of 5
I assume that means CAD. I don't know anything about that software and how it might use the hardware on a gaming graphics card. But something like a quadro or firepro are the types of cards designed to run software like CAD. But every one of those cards I've seen in a picture has only a single DVI and multiple display port. If your monitors can use display port or you are willing to use display port to DVI, I think you would probably be better off with one of those. But then again, I also don't know how those pro cards handle every day stuff a HTPC would run. My best guess would say that it's not going to be a problem at all. All this to say, I'm probably not the best person to guide you in this endeavor.
AMD Firepro graphics cards Eyefinity is their term for the tech that drives multiple monitors.
What I do know, is for a HTPC, that's beyond overkill. It's like taking an Indy car into pit lane. You could build a HTPC for well under $1000.
I don't know what other restrictions you have, budget, space, energy. Your double duty requirements are wildly different, and you might be better served building a much cheaper system dedicated to HTPC duties. While pumping all that heavy hardware into a workstation.
HTPC only has to run 1080p video and possibly some visual GUI. Those things are not that demanding. You can get 1080p video on tiny tablets now. The hardware required to run it is pretty cheap. You can get a card capable of producing 1080p for under $100, even. I've never had a need for one so I'm not totally informed on the lower end of the video card lines.
post #5 of 5
I would recommend a graphics card with at least two DP (Displayport) your priority.
It might be helpful if you said what type of software/work you're doing. If you are doing specific CAD work, then GPU memory size won't matter nearly as much as the type of GPU. A 1GB professional series GPU like the Quadro/FirePro/FireStream line will run circles around the highest end consumer (gaming) card with 3GB. (GPU memory matters, but only if the underlying hardware/software can use it effectively). While they usually have identical hardware, the firmware and driver optimizations of the professional cards allows for significant gains with CAD/CAM visualization and precision while sacrificing gaming abilities. In addition to that, some advanced features of CAD/CAM software simply won't be useable without a professional card. Check with the software company to see which cards they recommend.
For the price you're willing to spend on the 7970, I would recommend you get a FirePro V5900 or the newer W5000. Both are Eyefinity capable and have two DP and one DVI. You can use adapters to connect all three displays however you like.
Depending upon the application, it's possible that NVIDIA has a superior card - different apps respond differently to the hardware you use.
  Back to Forum: HTPC Gaming
