AVS › AVS Forum › Audio › Soundbars › Need Noob Help on Soundbar Purchase
post #1 of 6
Hello AVS...
I did 2-3 days of solid research on a soundbar and had it narrowed down to the Sony HTC-T260 or the Polk 5000 (really looking for best soundbar w/Bluetooth). Both of these models hook up via Optical and have no HDMI.
However, I looked at my POS Philips 7403 TV and found out it doesn't even have an Optical hookup....OMG!!! (has 4 HDMI ports total - using one for XBox and the other for BlueRay)
So it appears that if I want a soundbar for this television, the soundbar MUST have HDMI....is this correct?
How do the XBox and BlueRay hook up? When using HDMI on a soundbar, does everything plug into the soundbar...then a single HDMI to TV? Do you just keep the source on the TV the same at all times? How do you choose which HDMI device your using?
Confused a bit...
Any recommendations on a soundbar...with HDMI and Bluetooth??
Maybe it's new TV time....YIKES!!!
post #2 of 6
Did you look at page 32 of your TV owner's manual? Where it shows a diagram of how to connect a digital home theater amplifier? Your TV has digital coax out. If you purchase a soundbar that only has digital optical in, you just need a simple converter available at Monoprice, Amazon, etc.
post #3 of 6
I had no idea I could purchase such an adapter...I'm so used to looking at the square-ish hole (the one with the flap...TOSLINK??) as digital-optical.
Could you provide an Amazon link or search terms for me??
post #4 of 6
post #5 of 6
Thanks PG...appreciate it!!
One last question....would there any loss of sound quality when using this adapter? Typically think there is whenever you "adapt".
Think I read one review where DTS didn't work....
post #6 of 6
There shouldn't be any SQ loss going through an adapter. As far as DTS, you won't get that anyway when source device is connected to a TV. The BD player will downmix since it knows it is connected to a 2 ch. stereo device (the TV).
  Back to Forum: Soundbars
