I am building a new HTPC that will also be my daily work computer.
The computer/HPTC will NOT be used for gaming.
And for the video card, I am looking at;SAPPHIRE Vapor-X 100351VXSR Radeon HD 7970 GHz Edition 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Will this GPU run three monitors?
From the GPU I would like to;
Or I may just use standard HDMI cables with DVI to HDMI converters
Will this setup work? I am not planning on running all three outputs at the same time, either the two desktop monitors or just the projector.
Or do I need a second video card?
Thanks, Eric.
- Silverstone CW02 case
- ASUS Rampage IV Extreme LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard (if it fits)
- Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor
- G.SKILL Ripjaws Z Series 64GB (8 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) RAM
- Two 27" desktop monitors for work
- One through a Marantz SR7007 AVR to a JVC X30 projector
- NOT all at the same time.
- Use the HDMI out to the AVR - running the audio and video for the projector
- Use the two DVI outs with two 50ft HDMI to DVI Adapter Cable to the 27" monitors HDMI inputs
Thanks, Eric.
