AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › kilpsch rw-d12, PA-150 or BIC PL-200??
post #1 of 13
I need to buy a new subwoofer, my budget is very tight no more than 300$, Im considering these above options I have a BIC V1220 and Pinnacle subsonix 100-200. I want a good upgrade so i would sell one of them. PLEASE ADVICE
post #2 of 13
The Klipsch RW-12d - when on sale (usually at Newegg.com) for $300 - is a frequently-recommended option which is most likely your best bet.
Edited by eljaycanuck - 12/15/12 at 7:44pm
post #3 of 13
I would also be interested to know the answer...
post #4 of 13
http://www.avsforum.com/t/1390563/klipsch-rw-12d-omnimic-frequency-response-graphs - excellent review by Archaea, subwoofer RW-12D has been discontinued by Kliipsch (Oct 2012) but can still be purchased at some retailers. Often listed at $499 or $599 but is a real bargain when sold at $299.
You can read excellent reviews by Josh Ricci of the Premier Acoustic PA-150 and the BIC PL-200 at www.data-bass.com.
post #5 of 13
I'm gonna be using it for 50 music 50 movies, my current subwoofers produce good loud base but they can't hit too low. I want to feel some vibrations. Which would be my best bet?
post #6 of 13
If you have a strict budget of $300 then the RW would be the way to go. If you can swing another $50 or so then try to catch the pa150 on sale. It will give you more output. What is the size of your room?
post #7 of 13
My room is 17x13 ft
post #8 of 13
I would try to catch the pa150 on sale for $349 or so if you can. The RW would suffice but I think you would be happier with the 150. From what I understand the RW goes a little lower but the 150 is louder. If you want to go significantly lower than the rw you would have to rethink your budget.
post #9 of 13
I have the pl-200 and it is an absolute BEAST of a subwoofer. biggrin.gif Getting another one too. biggrin.gif
post #10 of 13
+1
http://home-subwoofers-review.toptenreviews.com/bic-acoustech-review.html
post #11 of 13
I have a really hard time recommending that site when there are no posted measurements and that site directly contradicts what Josh Ricci measured using the CEA-2010 standard (comparing the PA-150 and Bic200).
http://www.data-bass.com/systems
You can compare them here directly with each other. Josh is a well known and respected review with a passion for this stuff and he uses are very scientific and repeatable standard for his measurements.
post #12 of 13
Read this more often than not...now just have to find a place to buy th PL-200.
post #13 of 13
Hate to complicate things, but the Klipsch (which is often $300 at newegg) is $300 at newegg:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=-1&isNodeId=1&Description=klipsch+subwoofer
