So this seems very simple, but I'm not really understanding this so maybe someone here can explain this to me.
I would think that once I determine the screen size and the projector, the brightness is completely fixed and independent of zoom / throw distance, yes? To say it another way, if I move the projector twice as close and zoom in twice as much, my image size is the same -- so isn't the screen brightness exactly the same??
The reason I ask is that it doesn't seem to work that way on this calculator. Namely, if I keep the screen size constant, then move the zoom slider, the brightness also changes. This doesn't seem right to me.
http://www.projectorcentral.com/Sony-VPL-VW1000ES-projection-calculator-pro.htm
Obviously if I *don't* keep the screen size constant, but instead keep the zoom constant and move the projector back, then I lose brightness on a per-unit-area basis, because the projected image will be bigger.
Can anyone explain?
Can anyone explain?
