AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Plasma Flat Panel Great Found Deals! › best 3d plasma available under $1000
post #1 of 11
looking to upgrade my 42" lg plasma. Id like to have a new tv with the new features smart tv + 3d is a must ive never really tested these features so im not sure what tv is best. the biggest possible tv preferred id like to be around at least 50"-65" range the most bang for the buck deal. thanks!
post #2 of 11
BIGGEST bang for your buck would doubtless be another LG Plasma - you should easily find a 60" LG Panel in the sub-$1000 range, but do not know whether you will find "smart" features or 3D at that Price/Size combination.
Would guess that the vast majority of 2012 LG Plasma owners are very happy with their sets, even though Reviewers have given the nod to Panasonic and/or Samsung plasmas as having the best overall PQ of 2012 models.
Amazon's web site usually does a good job at showing the Feature Set of various models (from the same manufacturer), or take a peek at the home pages of the manufacturers themselves.
There are a number of review sites - CNet and Consumer Reports (not free) are good starting points. (The CR web site provides much more Detail about the tested sets than their magazine does.)
Happy Hunting....
post #3 of 11
appreciate the reply im currently between the 55LM6700 Lg and the Samsung PN51E8000 51-Inch. both a little over 1000 but not bad
post #4 of 11
If you have a newer bluray player with built-in apps and stuff, I wouldn't worry about that feature on your tv. I have a Samsung pn58c7000 and the 3d player (550 I think) that came with it. Thought I might use the smart stuff on the tv but never do since I stream movies with Vudu on the player.
post #5 of 11
I'm with ambesolman that it isn't worth paying more for something like the E8000, which just adds more features without any PQ improvement. You could buy a lower model and save money. FWIW, the 50ST50 can be had for $1,000 or less (and so can the 55UT50). It was $900 +tax through EPP, if it's still available (the 55" ST50 was $1,025 but sold out, last I checked). I would choose the ST50 myself, but if you prefer Samsung, then you should consider the E7000. Personally, there is no way that I wold buy the 55LM6700.
post #6 of 11
is $997 a good deal on the samsung pn51e7000 thinking i might go with that one
post #7 of 11
Yes, AFAIK, that's as good as it gets right now for that TV (online). Again, I personally would rather buy the 50ST50 for the same price, but if you want a Samsung, then that's a good price.
post #8 of 11
Yeah I'm ordering the PN51e7000 for 2nd TV (i have PN58C7000 in the main living room and love the PQ).
I was getting this at Sears which *might still have a $200 Sears Gift Card. Plus using Sears card gives extra 5% off which should be nice price.
post #9 of 11
That is a very good price for this model, which has been priced several hundred dollars higher most of this year. It is a top tier model for Samsung plasma, and almost identical spec wise to to the E8000, minus a few bells and whistles such as built in camera. Best Buy also has the $999 price, and last week was still offering a $200 store gift card. Samsung or Panasonic would be the best choices for plasma in the upper end models, although LG can be a decent bang for the buck in the entry level 1080p category. But I would still choose Samsung or Panasonic for best overall pic quality.
post #10 of 11
Ahhh 55UT50 or 50ST50 all the way
post #11 of 11
ended up going with a the 55lm9600 because i found a deal i couldnt pass up got it for around $1200 and sells for over 2 grand was a amazon warehouse open box couldnt pass it up smile.gif
