Is 1360x768 progressive scan or interlaced? I know its a PC resolution, but I'm not sure if progressive scan and interlace exist in the PC resolution realm. I was messing with settings on my 360 this morning and it suggested this as the optimal resolution. I had it set at 720p. Definitely a sharped picture as 1366x768 is my (720p) TV's native resolution, but experienced the color issues others had mentioned. I quickly fixed the color issue with a re-calibrating of that specific HDMI input.
Here are my settings:
Resolution: 1360x768
Color space: Source (supposed to switch between RGB and 790 based on the source)
Reference levels: Standard
This sound right for a calibrated 720p HDTV? I'm hoping 1360x768 is progressive scan or the equivalent.
Sorry if this a repeated subject, I'm new here. Any help would be greatly appreciated!
Jeff
Jeff
