AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › TV to fit in 28.5 inch wide space
post #1 of 3
I recently moved into a new house (built in 1940's) and the living room has a custom built in cabinet for the TV. The space is 28.5" - 28.75" wide. I'm having trouble finding a TV that fits the space. At this point, I'm not picky, I just want a flat screen that will fit the space. Anybody know of a flat screen with 28.5" width?
post #2 of 3
There are some 29 and 30" diagonal inch 720p LCD models which should fit in your space. There may even be some 32" models that will fit. Make sure you also have room for ventilation if the unit you get has ventilation slots on the side. I suggest you go to BB and Wall Mart with your tape measure in hand and see what you can find.
post #3 of 3
Hanspree and Coby both make TV`s that will fit this space. I purchased a Hanspree several years ago.
