AVS › AVS Forum › Audio › Speakers › Best 2.0 setup less than $200
post #1 of 6
I'm planning to hook it up to my PC. I also live in Canada, so it may be harder for me to acquire certain speakers and amps.
post #2 of 6
Ouch, tight budget. If I were you I would be looking at powered monitors, maybe some used ones. I would give Ebay a close look, and, if you are near a city, craigslist too. Behringer, Mackie, KRK, M-Audio, Alesis, some brands to keep an eye open for. If you have patience you can also snag a great deal.
post #3 of 6
I second the powered monitors suggestion for a 2.0 setup connected to a computer.
post #4 of 6
Do you guys consider Audioengine A2s to be better than the M-Audio AV40?
post #5 of 6
post #6 of 6
Find something used at Canuck Audio Mart...
...that (or kijiji) is where you will find the best value for $200.
  Back to Forum: Speakers
