AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Audio skipping when watching TV programs - Yamaha HTR-3065
post #1 of 11
Hi,
Just purchased a new Yamaha Home Theatre System (YTH-296) with a HTR-3065 receiver. During TV viewing I am experiencing audio skipping problems. At the same time, the display on the receiver blinks.
This is my equipment;
LG 42" Plasma TV
Samsung DVD Player
WD TV Live
The DVD player and WD TV Live box connect to the TV (both audio and video). I run a good quality Optical Cable from the TV to the receiver ONLY.
It's a simple setup but I don't understand the issue. Any help would be greatly appreciated.
Paul
post #2 of 11
How are the devices connected to the TV? HDMI, I'm guessing, if you're able to output the sound via optical?
If they are HDMI, you might try connecting them through the receiver to the TV to see if it solves the problem. The issue might be with your TV's sound processing, not the receiver. Connecting them the other way would reveal if that were the case.
Also, do you mean that the front display on the receiver blinks on and off?
post #3 of 11
There is no problem with the sound coming from the devices. The audio is skipping only during normal TV programming so I have proven. One device connects to the tv via Hdmi (wd tv live box) and the old dvd player connects to the av in ports. Audio to the receiver comes only from the TV via an optical cable. The optical cable is of good quality and ad I mentiined before the issue is not apparent when I select to play movies from either the dvd or the wd unit. It is only when I watch tv. I agree the issue is with the TV but remember the devices all run throught it as well so the ussue must be quute specific.
Selecting 'Straight' audio seems to rectify the issue too however the audio quality is poor on this setting.
Any clues?
post #4 of 11
Have you tried resetting the receiver? Sometimes that fixes issues like this. Aside from that I'm at a loss.
Edit: When you say "normal" TV do you mean that you're using the TV's tuner? Or do you mean TV versus movies from the WD Live?
post #5 of 11
Normal TV viewing via the TV's tuner. Audio skips and the display on the receiver also blinks. Does this every minute or 2 and is very annoying.
post #6 of 11
The blinking and skipping could be caused by two things: a faulty receiver, OR your TV tuner is sending an audio signal that interrupts every two minutes, causing the receiver to momentarily reset. Since you have no problems when you watch a DVD, it sounds like the TV's tuner. Sorry.
post #7 of 11
That was also happening when I connected a pioneer receiver to an LG 60" plasma.....
Would skip every few minutes, and the dts/dd lights would turn off then back on when it happens.
It was so annoying, just gave up in the end..... is it an LG plasma thing or what tongue.gif
post #8 of 11
Bought this Yamaha YHT-397 system for my father for Christmas and we are experiencing similar problems with the HTR-3065BL Receiver, a Comcast cable box, and a Vizio LCD.
Blu ray plugged into the receiver via hdmi works perfectly. Cable box plugged directly into the TV works perfectly. But cable box plugged into the receiver creates a flicker/signal interruption whenever he changes the volume, and the TV screen pops up the input display when doing things like changing channels or pulling up the receiver's setup menu. To make matters even weirder, he is getting some sort of audio interference when the microwave oven in the adjacent kitchen is running.
Since there are no problems watching blu ray, it seems like the problem would be the cable box, except that there is no problem with the cable box when bypassing the receiver. I've suggested that he swap the known good hdmi from the blu ray to cable to verify no issue there, and that he plug the cable box into receiver using a different input, to verify it's not a single bad input on the receiver, but otherwise am stumped. I know there are audio output settings on the cable box, but not sure how any of them would cause these type of issues.
post #9 of 11
Yours is a different issue--and one that can be fixed through settings I hope.
For the flickering while changing the volume issue, try unselecting all output resolutions on the cable box except 1080i (meaning that the cable box will upscale everything--including standard def channels--to 1080i). The receiver can only output its on-screen display and volume indicator at higher resolutions. If the cable box is sending 480p (maybe even 720p) signals, the receiver (and the TV) have to switch resolutions every time the OSD is displayed, which is causing the flickering and possibly the TV menus.
You don't have this problem with the blu-ray because it's always sending 1080p.
post #10 of 11
Thank you. Makes perfect sense. I relayed this response to dad and hopefully this solves it.
post #11 of 11
I had similar problem with audio skipping even on divx movies and just fix it...
You have to
1) disable ARC on your LG TV
2) connect optical cable as all sound will be traveling through that
3) choose external speakers on LG
4) choose optical output av4 in setup on Yamaha
It is working for me..no more audio skipping
