Originally Posted by Hudda
I would recommend going with the Onk 818, if for no other reason to get XT-32. It is superior even if only using one sub. More filters concentrating on low freq. modal issues means less flab/ringing. A room doesn't exist without these problems. I came from PIo and Advanced MCACC so I know of what I speak.
HSU is good, so is PSA. Might want to look at PSA more closely; Tom V. is highly respected around here.
Re: EMP Tek, you might want to poke around in the EMP owner's thread here on AVS before leaping. Yeah, they're cheap at that price but a quick look shows some flaws I couldn't live with. Someone posted graphs showing pretty wild FR variances between their L&R's. This is why David F. of Ascend makes a big deal about hand-matching L&R's within 1db (including printouts) before pairs leave the factory. There's nothing you can do about that once you own them. It's also a bit alarming to see references to nasty cabinet resonances, to the point guys are adding polyfil on their own. Those EMP's are also a bit low in sensitivity for my taste, especially considering they are rated at a nominal 6 ohm resistive load. No doubt, they'll dip a good bit lower in use which could mean either distortion or amp shutdown.
Perhaps take a second look at Ascend or Salk. Both are excellent and as someone else pointed out, you could pop for the RAAL tweeter with either manufacturer.
Chris
Chris
If you are referring to mine you need to keep in mind that im not in a completely square room, the left is in between a back and side wall while the right is in front of a back wall and a completely open space to the right of it. Can't be so quick to judge a speaker based on measurements in a room thats not treated and controlled.. The ascends would have the same issues in regards to dips in certain frequencie ranges. Can't blame bad room acoustics on the speaker.
I love my EMP's the BIGGEST issue IMO with them is their cabinet resonance, I myself have a few audiophile friends with systems mroe expensive than mine that are quite impressed with them and they dident even pick up on the resonance issue until I made them really listen and pointed it out.
You need to remember your referring to people that now live with these speakers and we are knit picking at them. I am extremely happy with their sound quality cabinet resonance aside (not even that big od an issue, and its a non issue in a movie/gaming enviroment, and most music its fine as well) When it comes to movies and gaming, which I do more of than anything, these speakers really sound great, I have never had a problem with resonance that I could hear anyways, and there is a lot of detail. As far as music goes, theres probably only a dozen songs ive listened to where the resonance shows up. To be hoenst, I don't think most people woudl even realize it or care unless they knew what and when they were looking for it.
Edited by Shady195 - 3/12/13 at 10:32am
