Some Info on XBL2 from the Adire tech paper.
http://www.adireaudio.com/Files/XBL2TechPaper.pdf
"XBL2 reduces distortion. Keeping the BL flat means more constant motor force at excursion, which means better tracking of large-signal inputs.
This advantage translates into directly measurable and audible reductions in distortion. For the example motors analyzed in this paper, the distortion figures are given for ±10.8mm excursion (70% of Xmax). The
XBL2 motor has less than 30% of the distortion present in the other motors.
XBL2 motors are useful for all audio transducers. While this example has focused on woofers, the advantages are also applicable for midranges and tweeters. In fact, the low inductance and moving mass of this
motor are extremely beneficial in wideband transducers. Typically, XBL2 will halve the inductance of a comparable-excursion overhung motor, which can result in adding a full octave of extension on the high end.
Add in the lower moving mass from the short coil, and the driver designer has a greater degree of flexibility in driver creation."
XBL2 isn't the absolute best its just another very successful way of designing a driver. Theres many other great drivers out there without XBL2 tech.
