AVS › AVS Forum › Audio › Speakers › Center channel speaker stand. Where to buy?
post #1 of 24
I am looking for a speaker stand for my center channel. It is an RBH MC-616C (approx 20" wide / 8" height / 9" depth and weighs 24 lbs). A simple yet good looking 12"-18" high stand would be perfect. I am having a tough time finding anywhere to buy a decent stand for less than $200.
Any recommendations on where to look would be appreciated.
post #2 of 24
I use a shelve that you buy pieces from lowes. It is a glass piece with four chrome legs.
post #3 of 24
post #4 of 24
I got mine from Crutchfield, it's a Sanus, specifically for center channel.
http://www.crutchfield.com/p_051NFC18B/Sanus-NFC18-Black.html
post #5 of 24
Not to hijack the thread, but anyone know of any products designed to simply angle up a center channel?
I'm using some $1.99 doorstops from Home Depot, but looking for something classier.
thanks!
post #6 of 24
I suggest that you get a small bookshelf unit which can hold CDs or LPs and put it on the top.
post #7 of 24
thanks!
Auralex has some pads to angle and isolate. About $45 though.
post #8 of 24
I suggest that you look at a simple bookshelf unit that can store CDs, LPs, or whatever.
post #9 of 24
My Paradigm CC-690 (37-1/4" (w) x 10" (h) x 16-1/2" (d), 70lbs.) sits securely on a Plateau ST-CC-17 stand, which a quick Google shows as retailing for ~$100. It should work very well for your CC speaker.
post #10 of 24
Thanks for the tip. I am looking for a center channel stand for my Definitive Technology Mythos 10. Is there a way to attach the speaker to this stand you mentioned above? Wont it tip over? I believe you just gently place the speaker on the stand, and there is no edges on the stand, or tilt to hold the speaker in one place.
post #11 of 24
Not that I know of.
Wont it tip over?
I have no doubt that if I were to push firmly on the speaker or the stand, they would tip over. But I have no intention of doing that. wink.gif
I put grippy shelf liner - similar to this stuff - on the top plate to help prevent any slippage. Many months later, still no slippage. smile.gif
post #12 of 24
While I don't have the center channel stand, I'm very happy with my stands from VTI. They are very sturdy/stable, look good (IMO) and reasonably priced.
http://www.vtimanufacturing.com/Central%20channel%20speaker%20stand.htm
You can probably find them on amazon. I bought mine from wayfair.com.
post #13 of 24
I use the stuff your place under area rugs to keep them from slipping; works very well.
post #14 of 24
Anyone thought about an Ikea Lack TV unit stand for their center channel speakers if they are huge?
something like this...
http://www.ikea.com/us/en/catalog/products/40105340/#/20105341
post #15 of 24
Why not go to your local muffler shop and have them cut down a 3" pipe welded to a piece of sheet meter at the bottom for the base, then a smaller piece of metal that is big enough to support the speaker on the top end made out of a thin piece of sheet metal as well. Total price should be no more than $80 bucks for a speaker stand that absolutely will not tip over, and can keep the cabinet vibrations to a minimum. I will try and post pics of mine later on.
post #16 of 24
Lack: 58-5/8" (w) x 21-5/8" (d) x 13-3/4" (h)
IMO, it's too wide (21" wider than my CC-690!), too deep and too short.
post #17 of 24
Thanks everyone for the info.
I have decided to go with a VTI DFC center channel stand.
Lots of nice stands out there but the max height I could work with was 13" (most stands were 18" high). Hopefully not a bad stand for 50 bucks. Reviews seem good for it.
post #18 of 24
I have decided to go with a VTI DFC center channel stand. ... Hopefully not a bad stand for 50 bucks.
VTI makes sturdy stands. I used to own a pair of VTI speaker stands for the surrounds in a previous HT set-up of mine, and they were very solid.
post #19 of 24
What stand would be perfect for these?
http://www.dynaudio.com/int/home_loudspeaker_systems/excite/excite_x22.php
http://www.bowers-wilkins.com/Speakers/Home_Audio/CM_Series/CM-Centre-2.html
It needs to be 24" to 25" high. Maby adjustable?
The CMC2 is huge, so i would need the right width and weight support.
I looked here- http://www.standsandmounts.com/centerchannelspeakerstands.aspx
But can't find anything 25" high?
post #20 of 24
thanks!
did you ever find a product for this problem, im looking for the same thing
post #21 of 24
post #22 of 24
post #23 of 24
thanks!
i just got these, i like the way they look
post #24 of 24
thanks!
SAME here i used door stopper to from home depot.
  Back to Forum: Speakers
