Originally Posted by
vinnie97
I was reading reviews for a modern entry range digicam above 10MP that reported on some fuzziness at the pixel level, so it's not unheard of.
Pixel-level detail is not important on modern cameras. For the same
image, the higher resolution camera is almost always better. (assuming they are of similar age)
vinnie97
And no, 4K is not needed until you reach a certain screen size threshold (and there's actually some content).
At 20-30" or so, 4K is a good fit for computer monitors. Above that size, say 40-46" and up, it's a great fit for televisions. Just like pretty much all displays are now 1080p from 20" and up, we will see the same thing happen with 4K in a few years.
rogo
There is no important part of the budget being spent on pixels; the imager in a $2000 D-SLR costs less today than the one in a $300 point-and-shoot from 10 years ago I'd bet. I'm well aware of all the noise and other imager problem. And I agree they should've stopped adding pixels millions of pixels ago (to some extent, they actually have on high-end cameras). But I think in diagnosing the problem, you overstate the cause.
As I have already demonstrated, today's DSLR optics are capable of resolving at a level equivalent to a 1500 MP sensor, and that was a 7D which uses a 1.5x Canon APS-C sized sensor.
We have seen the same thing happen with Nokia's 41MP Pureview camera outperforming everything else in the camera phone market. In good light, images from that camera are stunning, considering they're coming from a phone-sized sensor, and in low light, they have the lowest noise of any current camera phone.
tgm1024
You're confusing a few things. First, the highest resolution sensors are also the *biggest* for clarity, often "full frame" (36mm x 24mm), and now we're talking uber dollars, and these beasts are NOT what I'm talking about in the least. The number of people interested in the uber-expensive cameras fully outfit with uber-expensive lenses fills a thimble by comparison.
It does not matter if the highest resolution sensors are rated the highest for overall image quality. You are making precisely the same common mistake----a misunderstanding of precisely what it is I said. You're ignoring cost. You can always find the very top quality cameras with the highest resolution sensors.
You are changing your argument - initially it was that higher resolution sensors are automatically worse than lower resolution ones.
If you read the DXOmark site again, you will see that Full-Frame sensors with a 4.84µm pixel pitch are actually outperforming Medium-Format backs with a 5.17µm pixel pitch.
If sensor size (therefore photosite size) was all that mattered, Canon's 1Ds with a 12MP Full-Frame sensor and a massive 8.77µm pixel pitch would be right near the top of the list.
tgm1024
Further, there's a thing called chromatic aberration which often is very hard to correct for. This also has to do with qualities in the camera that have
nothing to do with how many pixels they deliver to the image file.
As I have illustrated, modern optics can
far outresolve today's sensors by a significant margin.
Advancements in RAW image processing can also significantly reduce or even eliminate chromatic aberrations from lenses. Just look at what Adobe is able to accomplish with the latest version of Camera RAW. (Lightroom 4/Photoshop CS6)
http://blogs.adobe.com/lightroomjournal/2012/04/new-color-fringe-correction-controls.html
And wait until they add adding deconvolution-based sharpening, we haven't seen anything yet.
tgm1024
AND, to make matters worse, cameras without a sufficiently sized sensor array end up making non-tripod non-optical-image-stablized images inherently fuzzy because of the nature of holding a camera.
And that is largely mitigated on camera phones through the use of the sensors built into them, taking the photo when the camera is stable, even when being hand-held.
Anything larger usually has optical or in-body image stabilisation.
But poor technique will result in blurry photos regardless of the sensor in the camera. I'm not sure of its relevance to the question of whether or not higher resolution sensors are better/worse than lower resolution ones.
greenland
Those very large units you cite are hugely expensive,and way beyond the budget constraints of the vast majority of potential buyers. Sticker shock will make all but the very rich suddenly come to their senses and realize that in any size under 65inches 1080P will do just fine
Is your argument that high resolution sensors or bad, or that cheap cameras are bad? This is just like the 4K argument, and the 1080p argument before that. The technology is somehow bad or unnecessary until it's affordable, then it's magically great.
720p was "more than enough" up to 65" until smaller panels with a 1080p resolution were affordable. Then it suddenly mattered at all sizes.
rogo
I am pretty familiar with the trajectory of digital cameras, understand what sucks about overly pixeled image sensors and agree with the vast majority of what you say on the topic.
Five years ago was another story. I bought into Fuji's SuperCCD with their F30/F31 pocket cameras, rather than buying a 12MP compact sensor with a lot of noise at anything over base ISO.
Those images look crap compared to most high megapixel compacts available today, especially now that many are offering RAW output.
rogo
I'm just (a) resigned to accept most of it (b) generally feeling like smartphones are within 5 years of killing off all but really good cameras anyway. So much more can happen in software that isn't going on yet which will mean the next generation of image improvements come there, not from hardware. That doesn't mean we couldn't have also improved the hardware. But with everyone already carrying a pretty decent camera, the idea of a
slightly better one becomes more and more pointless. This is why things like CD had no chance vs. MP3 (again, the analogy is imperfect).
Until we get phone cameras with interchangeable lenses, large sensors and huge apertures, cameras aren't going to die off. We will probably see the death of the low-end P&S market (superzooms will still exist) and probably see the low-end DSLR market die off to Mirrorless interchangeable lens cameras like the NEX and µ4/3 cameras though, with the high-end moving towards cheaper full-frame sensors.
