Hey everyone, I am starting to plan to modify a currently unused room where I am living into a HT area and I figured I should ask all of you for some help in planning and ask what advice you can give before I start working to help make my modifications easer. Please let me know what you think.
Here are some of the relevant details:
Room Dimensions:
12' W x 13' 3" D x 8' H
The room is 12' W running East-West, and 13' 3" running North-South. There is a fireplace and mantle on the Northern end of the room and a 72" wide window on the eastern wall. The southern end of the room is open, but there is a steel entry door, on the eastern wall in the corner of the room. I am planning on using the western wall to hang a fixed aluminum-frame screen that was used previously in another room. The dimensions of the screen are 96"W x 54"H.
These measurements are accurate to within an inch or so, I will update with more accurate measurements as I have them.
The home is a pre-fabricated home sitting on a cinder block foundation. There is a 4' crawlspace underneath the house, though I'd prefer to run things through the attic so I can work below instead of above my head. There is no conduit run to any part of the house. The attic is accessible, and runs the entire length of the house. The house was fabricated in two pieces, with the split running length-wise through the house. The western wall of the room is a seam-wall that I'm assuming is a double wall since there is a bedroom closet on the other side. While I am not the actual homeowner, my friend who is the actual homeowner has given me permission to transform the room. Her plan is to eventually sell the house an move out of the area in the next five years or so. That being said, I would like to do the minimum amount of cutting/drilling as possible, but still have a nice HT setup in the front room. Also, if I could plan my modifications in a way that they add some value back to the house when she gets it appraised in the future, that would be excellent. The house was renovated about 7 years ago just before my friend bought it, but it was a flip-house so the renovation was fairly cheaply done.
I'm a Computer Science major, but currently don't make a spectacular salary, so I'd like to keep the budget as affordable as possible. I am also not afraid of getting my hands dirty, drilling holes, or snaking cable; so I will be doing most of the labor myself alleviate that cost. I can also borrow most of the tools (drills, hole saw, fish tape, etc.) so I won't need to purchase those either, unless it's something unusual.
As far as adding to the house value, would it help to run Cat 5e/6 to the rest of the rooms while I am running my cable? Being a CS major, I have a lot of computers in the house already and have put a few runs under the house, but while I'm in the attic I was thinking of adding a couple more. At what point would it be ideal for me to install a centralized switch instead of adding smaller 8-port jobs to the rooms that need them?
Also, what order would everyone recommend I plan to do everything in?
The wiring for my devices currently is fairly linear:
Source -> HDMI -> Receiver -> HDMI -> Projector
I would like to keep it as much to this same linearity as possible so I can run as few wires as needed.
The equipment I currently have is as follows:
Yamaha RX-V765 Receiver (I would like to upgrade to a Network-capable receiver at some point)
Polk Audio CS-I center-channel speaker
Polk Audio RM8 LR channel speakers (I would like to upgrade these to something with a little more punch)
Polk Audio RM7 Rear-LR channel speakers (These work fine, but if I upgrade the RM8's, I will move those here)
Polk Audio PSW10 Powered subwoofer (eventually upgrade, but it's enough for right now)
BenQ W710st projector (I have tested this in the room in question and found the throw distance to be fine)
Apple TV 2 w/XBMC (this would be my primary video source for the short-term)
Popcorn Hour C-200 (not sure if I will be using this yet or not)
Equipment I still need, and might need help selecting:
Ceiling Projector Mount (I have no idea what universal ones work with my projector)
More Speaker wire (would like to go pretty cheap on this unless there are any pitfalls)
HDMI cable - I haven't measured the total run distance yet, but if it's greater than 25 ft. I would like some help extending this.
Outlet boxes and wall plates, or any equivalent that will make the cable terminations look nicer, especially in the ceiling.
Cable Staples
Ethernet cable - probably Cat 6 for future-proofing. I'm fairly familiar with this, so shouldn't need much help purchasing unless anyone knows of a brand-type I should avoid (STP vs UTP).
Satellite box - Currently there is a ViP-722k in the living room, with one RG6 cable using home distribution to a bedroom, so I'm not sure what extras I would need to put satellite in the HT room as well. Advice here would be much appreciated.
Some Brackets to mount the screen to the wall. The screen frame is made from 1" square aluminum tubing, and I haven't really come up with a good solution for mounting it on the wall yet. The whole thing only weighs around 10 lbs. There currently is no masking for the screen, but I would like to add it at some point in time.
Paint for walls and ceiling - not sure how high this is in priority yet, but I also don't know if it's better to do first or last.
Edited by TheAstronaut - 12/19/12 at 2:32pm
Room Dimensions:
Cable Staples
