I have a similar issue to some of those on this forum.
I would like to active the ethernet connection behind my living room TV so I don't have to use the wireless internet connection anymore for Pandora, Netflix, etc.
My home is prewired with Cat 5, but I am using a wireless network that originates in my study. There is an ethernet cable connecting my router to the only wall outlet in that room.
Here are three pictures of my media box to reference (assuming they attached).
Comms Box 1.jpg 2188k .jpg file
Comms Box 2.jpg 2075k .jpg file
Comms Box 3.jpg 2015k .jpg file
I initially I tried connecting a blue cable marked living room into a port (on a row labeled Open-Active) below the yellow cables in the second picture. Apparently the gray cable in the picture, which is plugged into the same row, is from my security system, because when I plugged in the blue cable next to it, my alarm panel beeped and indicated an error.
In the third picture, the two blue cables plugged together with the gray connector are labeled Uverse feed and Bedroom 1 data. I assume Bedroom 1 refers to my office where my internet originates.
Is the solution as simple as connecting the Uverse feed to one side (input) of an Ethernet Switch and the Data line (and others) to the output side?
thanks...
thanks...
