Any command between the AppShell Toggle Commands does not run.
I have created the install folder using either DVArchive or WiRNS and made sure the shellcmds file was perfectly edited and saved using TextPad
I only get the clock but not the cpu meter.
I also just put the ircodes, ircodesRaw, C1000fi.rid files directly in the Photo folder using WiRNS and no files would copy over to the correct paths as illustrated below:
AppShell ToggleClock
cp -f /name/storage/Photo/ircodes /name/system/user/mirror/sys-setup-gaea/data/irbdata/ircodes
cp -f /name/storage/Photo/ircodesRaw /name/system/user/mirror/sys-setup-gaea/data/irbdata/ircodesRaw
cp -f /name/storage/Photo/C1000fi.rid /name/system/user/mirror/sys-setup-gaea/data/irCodeset/C1000fi.rid
AppShell ToggleCpuMeter
Note: Even used the TextPad program and made sure it was ANSI PC format etc..
And as so many others... I get just the clock and no cpu meter...
If I comment out or remove the above 3 lines starting with cp for copy then obv. I get both the clock and cpu.
I have used just the Photo folder (viewable in WiRNS) and copied them directly using WiRNS but whenever I try to copy any files to the ReplayTV hard drive using the shellcmds file (which runs perfectly from C:\WiRNS) I only get the clock but not the cpu meter.
I have used and tried every combination and read 10 years worth of threads and about 100 posts just by you Henry and seem to be the only one on the internet that cannot copy over a file to either of these paths:
The above are paths and not files, and any file that I have in the Photo directory or any subfolder (ie install created in the) Photo directory will not copy over to the /name/system/user/mirror/sys-setup-gaea/data/irCodeset or to the /name/system/user/mirror/sys-setup-gaea/data/irbdata/
I can create folders/directories on the RTV5504 hard drive using either DVArchive or WiRNS and copy and move and delete any amount or combination of files and jpeg images until the end of time and have done so without any problems whatsoever using both DVArchive and WiRNS.
I even poll the Photo dir. capacity using httpfs commands and get updates via the browser before during and after file transfers to and from the Photo partition directory:
0
cap=999948288
inuse=1310720
0
cap=999948288
inuse=5439488
I have tried new drives and even reset the drives by doing a 382zones etc, RTVPatched with brand new 5.1 images from builds 19 to 144 and still experience the inability to copy any files to the system partition... even if I just try to overwrite an existing file just using a single Cxxxx.fi.RID like you did on one of your Replays, Henry...
I have used and am experienced with setting up and using WiRNS 2.1 and 3.0 and DVArchive and can do ANYTHING with the replay except control my Zenith DTT-901 box because I cannot load any codes...
I am currently looking for the best instructions using extract_RTV to put them directly on the RTV hard drive.
At this point: I welcome any tips, tricks, advice, darts, jabs or even insults as I am beyond bullet-proof at this point.
0
cap=999948288
inuse=1310720
0
cap=999948288
inuse=5439488
