AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Crestron iOS devices
post #1 of 2
Hi. Not sure if this is posted in the right spot. I've purchased the Crestron Mobile pro app and my home a/v was programmed onto my iPad. Unfortunately, this is the only way we can control our TV. I took the iPad to work accidentally and the wife is left home with the kids and no way to control the TV. Is there a way she can download a Crestron app on her iPhone to use for today that can recognize what's been programmed on my iPad at work? ie, can she download an app that will turn the tv on?
thanks
post #2 of 2
I have never tried to do that but technically your iPad project should not work on an iPhone because of the difference in resolution. Assuming that she had another iPad she could install the same app a with the same settings as your iPad app and it should work. Alternatively, you could ask your programmer to provide you with an Xpanel that would give the same interface as your iPad but would run on a PC or a Mac.
  Back to Forum: Home A/V Distribution
