ok, have read a few comments from way back that some users found that plugging 1 or 2 (out of 3) of the rear ports on the Paradigm PS-1000 sub made it go lower. Over the years, I have read many users who complained about this bandpass design sub sound too boomy for music. Since owning this sub, and not doing too much with placement, I just made sure it had enough breathing room between ports and the wall, music has never been boomy. More one note maybe, but never boomy.
Started to fiddle around with the system again and ran Audyssey again, adjusted all speakers to small, crossed at 80Hz on the receiver. Movies never sounded better. Since getting a Denon receiver with Audyssey, I have packed away the decibel meter and AVIA calibration DVD. Took it out today and was pleasantly surprised that the sub could go down to 30 Hz nicely. After that, fall off was dramatic to 25 Hz. < 25 Hz, although there was pressure and sound, I would not consider this audible in a movie setting.
Now, the question is, will it damage the sub if i plugged 1 or 2 of it''s 3 ports to test frequency output? It's a bandpass design and here is a direct link to Paradigm spec sheet: http://www.paradigm.com/index.php?option=com_joomdoc&task=doc_download&gid=464&Itemid=8
Can anyone shed some light on this matter? Would love to try it and test with the AVIA low frequency sweep test but afraid plugging the ports might damage or shorten the life of the sub. Afraid of over heating as well since it is a bandpass design.
Anyone care to share some thoughts?
