AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › diy screen for lg pa70g
post #1 of 64
I'm looking to make a screen for my recently purchased LG PA70G, . I'm looking to build a fixed screen for around 200$. light control is easy as it is dark with walls covered.
I'm going to set it up on a concrete wall in a 15' by 24' room in the basement with screen on 15' wall, and projector setup on a ceiling mount from monoprice. I was thinking it should be about 12' from the wall for a 120" screen. can someone please help me to find if WA DW 5x10 is an option for my projector?, mostly will be used for movies and occasionally for gaming. is screen bigger than 120'' diagonal ( as wall is 15 feet) an option for me considering the lumens of this projector.
i was thinking of building one like this http://www.avsforum.com/t/1303114/amazing-grace-theater-build , or can someone please help me with link to thread which has frame build out (popular one)
or this one http://www.avsforum.com/t/1250379/diy-wa-dw-120-screen-finishing-help-needed seems more complicated than the first one above.
Can anybody recommend any other specific material/option for screen?
g1
Edited by sdmbbs - 12/21/12 at 11:55am
post #2 of 64
Can someone please suggest me on this screen build.
TIA
-g1
post #3 of 64
Well Sir,
With the LG having no Zoom and the need for exact placement, if you can work around those considerations, WA-DW might be a decent choice. The LG only sports 700 Lumens, and at 120" it will produce 16-17 Foot Lambert of reflected light off the WA-DW, under the assumption the WA-DW is at least 1.1 Gain.
Also, with such a dearth of Lumen output, it's probably a case where you may not experience any Hot Spotting from the slight degree of sheen the WA-DW possesses.
Essentially speaking, your biggest challenge will be the Build itself, as cutting the material to size, building a proper Frame, and getting the laminate glued onto said Frame properly without damage or error are the hurdles you must face.
But as the threads you have over viewed show, it's been done before...and done successfully with very plaudit-ed results.
Your only other basic choice would be to use a 5' x 10' x 6mm sheet of Sintra / Kometex, and paint it with a Bright White OTS paint. Sintra / Kometex is silly easier to work with.....I mean A LOT EASIER to work with, and carries NONE of the aforementioned risks or difficult build characteristics.
post #4 of 64
Thank you MM. I will try to get komatex, there is sign supply store which has 5x10 for around 90. I will keep posted about how it goes, can you suggest of any popular thread for frame build for komatex with material needed.
Thanks again.
-g1
Edited by sdmbbs - 12/23/12 at 12:03pm
post #5 of 64
Well I've done a few....so let's just do yours "in House" and post up your progress as you go forward.
First off, get the PJ up in the air and shoot a properly sized & squared Image onto the wall to obtain a definite location of your screen's edges.
Then Mount the exterior 1x4 Poplar Frame pieces directly onto the Wall so that their inside edges are 2" inside what will be the leading edge of the viewable screen area. Also add 3 vertical pieces placed equally distantanced across the opening between each outside edge.
Now take 3/8" Drywall and screw it to the Wood forming a flat substrate.
Next you simply Glue the Sintra / Komatex to the Substrate.
Sound plausable?
post #6 of 64
OK, thank you, let me get the frame material tomorrow. I would like to make the frame hangable since my concrete wall is not painted yet, are they called cleats? Sorry for my ignorance wrt terminology.
post #7 of 64
Originally Posted by sdmbbs View Post
OK, thank you, let me get the frame material tomorrow. I would like to make the frame hangable since my concrete wall is not painted yet, are they called cleats? Sorry for my ignorance with terminology.
OK. you'll need a few extra pieces of hardware. And either Rip a piece of 1x8 in the middle @ 45 degrees to make a wooden French Cleat, or purchase one of these:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=202341629&storeId=10051&langId=-1&catalogId=10053&ci_sku=202341629&ci_kw={keyword}&kwd={keyword}&cm_mmc=shopping-_-googleads-_-pla-_-202341629&ci_gpa=pla
If the screen is going onto Concrete, You will want to do some pre-drilling of Holes into the ?"Blocks"? or wall and use Concrete Wall Dog Screws.
The frame should have Mitered Corners, inset Corner angles, at least 2 vertical "Center supports,and every "joint" supported by a "Simpson Strong Tie" bracket ("T" or "L" or "Straight")
http://www.homedepot.com/h_d1/N-25ecodZ5yc1v/R-202034207/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=Simpson+Strong-Tie+Corner+Brace&storeId=10051
http://www.homedepot.com/h_d1/N-25ecodZ5yc1v/R-100374887/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=Simpson+Strong-Tie+Corner+Brace&storeId=10051
http://www.homedepot.com/h_d1/N-25ecodZ5yc1v/R-100374961/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=Simpson+Strong-Tie+Corner+Brace&storeId=10051
post #8 of 64
ok i will get the material, do i still need 3/8'' drywall if i am hanging frame with "OOK Hangman 200 lb. French Cleat Picture Hanger with Wall Dog Mounting Screws (13-Piece Pack)". my frame will be 2 inches more on each side of my screen area?,is this correct?. i am planning for 122'' diagonal, 60x106 16:9 size screen.
post #9 of 64
No Drywall is required.
Yes...the 2" Under-hang allows you an area on which to affix your Screen Trim.
post #10 of 64
So do I nail komatex to the frame along edges?
post #11 of 64
No.
First you apply a White adhesive ( Power Grab or "White Lightning 2003 Adhesive Caulk) to all the wood surfaces and spread it out evenly, then after placing the Komatex / Sintra "Face-down" on a clean flat surface, you place the Framing on top, pressing it firmly into place.
In fact, if you can do the procedure as directed, you can actually assemble the Frame piece by piece directly onto the material a piece at a time, taking pains to be sure all pieces are precisely in place and the edges are flush. Then, after the adhesive is "set", you can attach all the brackets and not have any worries whatsoever that the framing members will shift during assembly.
The sequence would be:
Top Horizontal piece
All vertical pieces
Bottom Horizontal piece
BTW, be sure your sheet material is square, and always pre-assemble everything first to assure that it is all gonna fit. Use a Pencil and mark off the inside edges of each Framing Piece to also make sure you can easily place them exactly where they should go.
The method above makes the construction of a Large frame a one man job.
post #12 of 64
Sounds like a plan.. thank you.. so the screen will be glued only to wood and not whole area of screen right, this will not have bumps in future like laminate as its different material?. And for screws to brackets I can refer to parts from Amazing theater thread?
This is where I saw for 80$ for 5x10 ,
Is this the correct one?
http://www.alumapanel.com/view_product.cfm?step=1&lines_ID=317&name=Komatex%20White
Edited by sdmbbs - 12/24/12 at 10:12am
post #13 of 64
Yeah...and at a killer price too boot!
You can be sure that 6mm of thickness is almost 4x as thick as Horizontal Grade Laminate, so any adhesive that is properly spread will not transmit any "lumps or bumps".
post #14 of 64
post #15 of 64
While I am waiting for screen material should I look at paint as suggested above?,hoping above material will hold my frame?
Thanks for the help.
-g1.
post #16 of 64
Does anyone know what might be the approx weight of the komatex 6mm 5x10 sheet
post #17 of 64
25 lbs max.
post #18 of 64
thank you Mississippi man. Can I use this for bordering of screen to wrap it to trim.
http://www.syfabrics.com/View.aspx/Plush-Triple-Velvet/Black-Plush-Triple-Velvet/681/264
Should I get paint too for screen.
G1
post #19 of 64
I just use the exact same velvet fabric to wrap the screen frame, it looks fabulous
post #20 of 64
Thanks werewolf84. 3.5 yards should be enough for 122'' diagonal screen?
post #21 of 64
I bought 3 yards for my 116" diagonal16:9 AR screen
post #22 of 64
G1
Absolutely. As to what type paint......?
Your circumstances as stated in the first post would lead me to suggest RS-MaxxMudd Standard if you want a high performance paint mix that will easily allow you to run the LG on Low Lamp and it's best calibrated mode / state.
The RS-MM will maintain all the brightness you'd need, while also enhancing the prevailing Black Levels.
Spraying will / would be best, but a very careful job of rolling can get you started.
If "careful" is not within your grasp when rolling (...nothing to be ashamed of...) then a simple, light Neutral Gray in the 8.0 Munsil Range can be rolled on by almost anyone. Almost. wink.gif
post #23 of 64
thank you MM and werewolf84, let me look at threads for rs-maxxmudd, so i need to make it grey color screen?, will it involve mixing paints?, i can try to do this light Neutral Gray in the 8.0 Munsil Range, can you give a link for this, will this also give nearly same results as rs-maxxmudd?
regarding velvet from above website, they let us order either 3 or 4 yards only and not 3.5, will 3 yards be enough for my 122'' diagonal 16:9 screen?
post #24 of 64
Any "standard" neutral Gray...even a very light one, will always come in under 1.0 gain. RS-MaxxMudd is always "over"...with RS-MaxxMudd LL @ 1.3+
Best to choose / use a Interior Flat Enamel
~N8.5 DIY Tint {Medium Gray}
Quart Custom Tint
Behr UPW (1050,1750,1850)
048 Lamp Black
011 Brown Oxide
005 Medium Yellow
Gallon Custom Tint
192 Lamp Black
043 Brown Oxide
019 Medium Yellow
~N8 DIY Tint {Dark Gray}
Quart Custom Tint
062 Lamp Black
014 Brown Oxide
006 Medium Yellow
Gallon Custom Tint
Behr UPW (1050,1750,1850,4850)
248 Lamp Black
056 Brown Oxide
024 Medium Yellow
BTW, as to velvet length needed.
A 10' 2" diagonal screen is 107" "inside of width.
3 Yards = 108"
Of the Trim is Mitered at the corners, then you must add to the length of velvet required an amount equal to 2x the width of the trim.....minimum Usually on such a large sized screen, 3.25" MDF is the "Go To" material. So 3.2" x 2 = 6.4"
And, you need extra material "length-wise" to pull the material tight and them trim away the excess.
Short answer: You'll need 4 yards.
post #25 of 64
Thank you MM for all the info. Should I go with medium grey? And should I get quart or gallon for my 122'' diagonal 16:9 screen?
post #26 of 64
Actually, I'm going to pull back and tell you what you really need to do for a big screen is to go with RS-MaxxMudd LL. At 700 lumen output, and a screen of 122" diagonal, you really cannot afford to chance using any Paint that comes in under 1.0 gain.
That, and as your a Noob at this Screen painting business, RS-MaxxMudd will be / is more forgiving because it has a dual application potential. It can be either Rolled or Sprayed on.
post #27 of 64
OK, just to make sure I am clear, can you please help me with rs maxmudd LL material like n8.5 or n8.0 above.
G1
post #28 of 64
I bought 3 yards for my 116" diagonal 16:9 screen with some leftover after wrapped all the frames. It's safe bet if you are buying 4 yards or more for your larger screen size
post #29 of 64
thank you werewolf84, i will get 4 yards.
post #30 of 64
  Back to Forum: DIY Screen Section
