AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › diy screen for lg pa70g
diy screen for lg pa70g - Page 2
post #31 of 64
Originally Posted by sdmbbs View Post
OK, just to make sure I am clear, can you please help me with rs maxmudd LL material like n8.5 or n8.0 above.
G1
RS-MM LL is almost a full fledged n9.0+ in appearance but acts like a n7.5 as far as Black Level enhancement. The combination of having appreciable Gain while also being able to improve Black levels, produce vibrant colors, and maintain bright Whites on the screen is what makes RS-MM LL the advantageous Mix that it is.
post #32 of 64
is this the one you are referring to?
RS-MaxxMudd LL v.2(for lower lumen pj's and controlled light home theaters)
20 oz. Delta Pearl Metallic #02601
8 oz. Liquitex Basics Silver
12 oz. UPW flat
12 oz. Minwax Polycrylic - Satin finish
15 oz. distilled/tap water**
this is the only mix of the rs-maxxmudd family that can be rolled
The Liquitex Basics Silver is found at Michaels, Hobby Lobby, or Dick Blicks. (Artist's paint area)
The Delta Pearl Finish is also found at Michaels, Hobby Lobby, or Dick Blicks. (Craft paint area)
The Behr 1850 and Minwax Polycryic is found at Home Depot, Menards, Lowe's, Walmart, Ace.
post #33 of 64
Yes...but the Delta Pearl is extremely scarce....though strangely enough a quick search turned up these sources:
http://www.createforless.com/Delta+Ceramcoat+Acrylic+Gleams+8oz+Pearl+Finish/pid39478.aspx
http://shop.plaidonline.com/delta-ceramcoat-acrylic-paint-pearl-finish-8-oz/026010802W/item.htm
http://www.hancockfabrics.com/Ceramcoat-Acrylic-Metallic-Paint-8-Ounces---Pearl-Finish-Craft-Paint_stcVVproductId47602464VVcatId540012VVviewprod.htm
http://www.amazon.com/Plaid-Delta-8-Ounce-Ceramcoat-Acrylic/dp/B000YQK3CA
This substitute is primarily used now:
http://www.amazon.com/Rust-Oleum-Metallic-253611-Decorative-32-Ounce/dp/B003EELN1Y
Obviously, if you can get 3 -8 oz bottles at the lowest price shown in the provided links, you'll save some cash.
But you had better hurry! When I find these type bargains, I often stock up and wipe out available inventory. cool.gif
post #34 of 64
ok, let me go through these links, trying to gather all material needed. i found this below quote from another thread, do i need both delta pearl metallic and liquitex silver?
Originally Posted by trax179
Hi ,
Can someone help me. Hope Depot dose not carry Metalic paint anymore. Not sure where to get Meatalic paint for the RS-MaxxMudd. Any one has any idea ?
Look right to the post above....here's a direct link.
http://www.avsforum.com/avs-vb/showt...0#post19569840
PB....why does the ingredient listing on the 1st page not contain the sources?
Also, the Delta Silver Metallic has now been replaced by the Liquitex "Silver". This is a "Artist Paint" that comes in a Tube and is found in the "Art Supplies" section, not in the "Craft Paints" section where the Delta paints (Pearl Finish) is found. Please update the 1st page.
post #35 of 64
That is what the recipe calls for....yes? Your just getting off a little easier "cash-wise" by being able to substitute the 3 individual 8 oz Bottles of Delta Ceramcoat Acrylic Gleams Pearl Finish (24 oz total) for the more expensive 32 oz Jar of Rustoleom Metallic Accents - White Pearl
post #36 of 64
thank you MM, i bought 3 - 8oz bottles from below for around 19 something..
post #37 of 64
Including Freight I hope since for 3+ the price shows to be under $5.00 a bottle.
Either way that's only 1/2 of what a 32 oz Jar of the other Pearl Finish costs...before freight.
post #38 of 64
yes includes shipping..
remaining these now:
12 oz. UPW flat
Edited by sdmbbs - 12/31/12 at 1:32pm
post #39 of 64
saw this for v.2.1, do i need 10 oz or 8 oz of Liquitex Basics Silver?, i can also spray this right?
RS-MaxxMudd LL v.2.1
20 oz. Rustoleum Metallic Accents - White Pearl
10 oz. Liquitex Basics Silver
12 oz. Behr 1850 Ultra Pure White - Flat
20 oz. distilled/tap water**
post #40 of 64
It does say 10 oz.
Of course you can spray. The comment shown only alludes to the ability to rill if one has to.
Spraying is always to be considered as being the preferred method of application.
post #41 of 64
Thank you MM. Wishing a happy new year to the entire avs forum family.
post #42 of 64
It seems alumapanel stocks ex-cel white and not komatex white.. is the below sheet same as komatex... MM can you please give your thoughts on this...
Ex cel white
http://www.alumapanel.com/view_product.cfm?step=1&lines_ID=317&name=Ex%2Dcel%20White
Komatex white
http://www.alumapanel.com/view_product.cfm?step=1&lines_ID=317&name=Komatex%20White
G1
Edited by sdmbbs - 1/2/13 at 7:59am
post #43 of 64
G1
Yeah....I could spit nails! That's an incredible price for 120" x 60" x 6mm white PVC Foam Board
Run....don't walk and get some! Shoot, I might flit on down to Alabam'y and get me 3-4 sheets myself!
post #44 of 64
just got the 5x10 sheet delivered. the lady at aluma panel says the sheet will be around 50 pounds, will my two 75 lbs hangman (http://www.lowes.com/pd_56156-37672-122371_0__?productId=3058191&Ntt=hangman&pl=1&currentURL=%3FNtt%3Dhangman&facetInfo=) hold this or should i get two 200 lbs just to be on safe side.
thanks,
g1
Edited by sdmbbs - 1/3/13 at 8:21am
post #45 of 64
the cheapest sprayer recommended here seems to be around 60$, did anyone try renting the sprayer from home improvement stores?
g1
post #46 of 64
g1
None of them have this kind of Sprayer, and frankly....even if they did you'd spend as much or more to rent one, and perhaps have to deal with equipment not ideally suited for the job, or already worn to a frazzle.
Don't worry...it's a good investment for now...and you will find use for it later as well.
post #47 of 64
thank you MM, i really appreciate all the good work you do here.
is this the cheapest (for 59$) available now? http://www.amazon.com/Factory-Reconditioned-Graco-HV2900-Paint-Station/dp/B005QQ0AFS
is this damage on the edges ok for the sheet?, this is what i got.
Edited by sdmbbs - 1/3/13 at 9:25am
post #48 of 64
Seems to be. 2 months ago it was going for $39.00 from the same source, but let's face facts. When we start sending as much business to such Vendors as we are apt to do when things get crackin', the Laws of Supply & Demand kick in and prices go up.
As long as the damage is limited to the outside edge, and your butting Trim up flush against that edge, there should be no worries. Ditto should trim overlap the edges.
post #49 of 64
You can get a refurbished HV2900 with a new gun from Gleem Paint in Gulfport, MS for $49.00 + shipping. (FYI - shipping to Phoenix, AZ via UPS Ground was $13.08. Total for sprayer & freight $62.08). I have purchased 2 sprayers from them and both work great. Here is a link: http://www.gleempaint.com/noname.html
post #50 of 64
thank you, i just looked at it, with shipping its coming to around 62 something, the one at amazon is 59 including shipping.
post #51 of 64
remaining things to get: basics liquitex silver, sprayer, strainer, mixer, do i need mixer, i dont need sanding material right or do i?
post #52 of 64
here is the progress so far:
sheet and mdf:
post #53 of 64
should i nail at the left and right edges as shown below while attaching sheet to frame along with adhesive?, if so can you please help me with what kind or size/number.
post #54 of 64
Hang on......don't be hasty.
post #55 of 64
Ok sure...what route should I take..
Edited by sdmbbs - 1/3/13 at 7:45pm
post #56 of 64
is this all purpose power grab adhesive good one to glue komatex to frame or should i use heavy duty one instead of all purpose from powergrab?
http://www.homedepot.com/h_d1/N-5yc1v/R-203009256/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=power+grab&storeId=10051#.UOcO1G9QXN8
Edited by sdmbbs - 1/4/13 at 9:30am
post #57 of 64
I am trying to cut mdf at angle which is 1'' larger than frame on each side. Should I make inner side or outer side 1'' larger than frame?
Can you please help me with above questions for glue and process to stic sheet to frame.
Jeevan
post #58 of 64
Use the All Purpose...it's more than sufficent.
Jeevan
Explain is better. Either it's too early, or my Coffee is having no effect whatsoever on my cognizant ability to comprehend your explanation.
Be hasty with your reply...as I'm ensconced at my PC at present.Ask whatever you may. biggrin.gif
post #59 of 64
since i am cutting mdf at 45 degree, the length between which edges/corners of mdf should be 1'' larger than wooden frame, the inside edges/corners or outiside edges/corners?, i mean the length of mdf after cutting at angle, length from outside or from inside, which one should be 1'' larger than frame
along with glue on wooden frame for sheet should i nail the right and left edges of sheet to frame and what nail and washer should i use?
and also should i wait for painting to be done before i glue the sheet to frame?, so that i have other side of sheet if i mess up one side of it?
Edited by sdmbbs - 1/5/13 at 8:25am
post #60 of 64
Man.....I fabricate all sorts of things all the time, but without a rough drawing of what your describing, I gotta say I'm just about clueless as far as understanding what it is your describing.
I don't know why you need 45 degree cuts, or why the Mdf needs to be just 1" bigger / smaller than the inside / outside edges.
...........but I do know this for certain. Painting first and then attaching last is fraught with risks. Even if you nail the first side's coating, if you mess it up while attaching it, then you have no option left anyway. Better to create the entire assembly, hang it in place, and then do a "Best Job" at painting the screen surface.
  Back to Forum: DIY Screen Section
