While helping my Mom flip a house recently, I was paid and told I could keep anything left from the previous tenants... I needed a tv to replace the one recently broke in my kids play room... I was going to use the Sony Trinitron Wega KD-36fs13 that was found left in the house for my kids play room, their tv recently broke...
I checked to make sure it worked, it did... We loaded it into my sisters truck and I asked her to hold onto it because I wasnt going to my house that night... 2 days later when I went to retrieve it, it was still sitting in the driveway where I left it... Her similar sized tv and fridge and all the stuff she took were put away safe in the house... My one thing I took was left out in the florida humidity, the dew was quite heavy both those mornings, too!!!!
I got the set home, power and all the connections are fine... The only problem is the screen is off color in all four corners... Its that coloring you get from a magnet... There is a chance the screen was like that and I didnt notice it when I checked to see if it worked, but I really think I would have noticed the colors on the no signal screen...
- If it was already there, can this be fixed? How? Links please...
- Would the moisture have somehow caused the internal magnets to no longer be shielded??
- Would the moisture itself cause this discoloring, going away after it dries??
- I will rarely use the internal speakers over my surround sound anyway, is it easy to go in and just remove the speakers??
Any help would be appreciated...
