HI Guys,
I have been reading a lot on this forum and finally decided to ask my questions.
I have done a few DIY screens for myself and friends using BOC and all them have turned out well. But recently I ran into a post of DNP Supernova Blade screen and I have been drooling over it ever since. I dont know if the price of ~3000$ is justifiable for the screen but I just dont want spend that much money on a screen. Hence I would like to build one similar to it. While I do understand that the screen material they use is of very high grade and works well with ambient lighting, the form factor is what impressed me the most.
I'm trying to build something similar to DNP Supernova Blade or SI Black Diamond Zero Edge with back lighting. More of mimicking the form factor.
I'm using an Epson 8350 projector in a fairly light controlled room and 120" screen would be ideal.
Here are the options that I have considered
1) Sintra board glued(?) to a thin wooden frame with LED back lighting.
Pros:
Cons:
2) Wilson Art Designer Weight Laminate glued to wooden or metal frame with back lighting
Pros:
Cons:
3) Work with BOC. I doubt if this is going to give me the Blade or Zero edge look?
Experts here please share your experience and suggestions?
Pros:
- Highly recommended in most threads.
- Light weight,
- Paintable and probably will give me the best look.
Cons:
- I live in St Louis, I dont think there is any place carries it around my city
- hard to transport
- it needs painting and cant be used as is
Pros:
- Easily transportable (can be shipped)
- Sturdy (?)
- Can be used as is (no painting required).
- Easily Available (I dont know where to buy from, any suggestions?)
- Could have a great look
Cons:
- Heard abt hot spot issues and also saw a picture of one screen made out of laminate in terrible shape with bumps
- Durability
- Needs a heavy frame?
