AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Count 1 more for all receivers sound the same
Count 1 more for all receivers sound the same - Page 8
post #211 of 540
Originally Posted by JD in NJ View Post
Think about it, the purpose of amplifier is to amplify a signal, not to change it in any other way. The closer the output is to an exact magnification of the input, the more provably "correct" the amplifier's function is. Color and change the sound all you want, run it through a series of guitar effects pedals if you wish, but the amplifier really doesn't have a place in coloring the sound because that's an uncontrolled variable in the chain.
I can insert a tube (or digital simulation of a tube) into my signal path if that's what I want to hear. I can also turn it off.
JD, I am kind of losing the scope or point of this thread and I think I am not the only one here. First it was all receivers sound the same, which is a total myth and impossible. I can move this receiver into another room and it will even sound different than it does in here. Now it's only if you run it in direct mode, which is still not true or reality because you are not going to set your receiver up like that. Would you want to watch a movie in direct mode? I would not for sure.
Amps can and will sound different because there is a such thing as signal paths and amp performance. I can buy a cheap 100 watts x 2 Pyle amp but to expect it to perform the same as my Pioneer Elite is folly, the specs simply do not match up. Just as I cannot expect the Pyle to outperform the Sansui, the dynamics simply would not be the same and no way will the Pyle sound anywhere near as good as it. An amp is just one of the 1000's of variables that exist from one receiver to another. In certain controlled environments, I am sure amps would sound similar. If using poor speakers, maybe you cannot hear the difference as much but not hearing it does not make it disappear. In the real world, DSPS, OPAMPS in the DAC, the input used, room correction, the room, the speakers, etc. All these things change sound quality. It's called reality (real listening) vs unrealistic environment (ABX).
While it is true an amplifier's job is to take a signal and amplify it, there any many different and now more exotic amp types. Solid state, tube, chip, digital, A, A/B, D3, hybrid, discreet, etc. No two amps have the same specs, this is why the more expensive receivers sound better than their lower end counterparts. This is why you would buy an Anthem over a midrange receiver because you are paying for the sound quality and amp quality. You are getting less features with that more expensive Anthem, therefore if they are sound the same an Anthem or Nad or Cambridge would be useless to own when you can get a cheaper receiver for 1/3 the price and get more features to boot.
Arny and Kbarnes701 remind me of cultists, they think ABX tests are "common sense" when I find them unrealistic and biased towards people like themselves. ABX is an unrealistic environment. If an ABX test was carried out by using receivers at their full potential, I bet the differences would be very apparent. Do not mistake, I do think ABX tests are interesting and the results interesting, but it is just funny that exactly half were able to pick out the difference, but according to boiled spinach boy that is just "random guessing".
Edited by Ricsim78 - 2/8/13 at 11:47am
post #212 of 540
Originally Posted by Todd68 View Post
Originally Posted by Theresa View Post
Bass response and "tonal balance" (frequency response) are easily measured and most amps are equal in that regard. Better "dynamics," and better "soundstaging" cannot be quantified so remain highly suspect. As someone said, that which is offered without evidence does not require evidence to refute.
But why then did Bryston, Carver and even Emotiva? (to name a few) tweak their amp designs over the years for better sound, even though the earlier designs were "perfect" regarding basic frequency response specs?
I guess you are are unaware of the fact that frequency response is not the only SQ related parameter in amplifier design or you would not have asked the question above.
News flash: Frequency response is not the only SQ related parameter in amplifier. Presumably each of those vendors had some other issue to address.
The question is very strange - it is something like "Why did the chicken cross the road?"
post #213 of 540
Arny, I don't believe amps make more of a difference in SQ than speakers and the room.
It takes a lot of technical naivete to put rooms and speakers into the same comparison as good amplifiers. Rooms and speakers generally have frequency response variations of many dB while amp's variations are only fractions of a dB.
It is this kind of lack of being properly informed about audio basics that leads to statements like the following:
"But it just hard for me to grasp the idea that all sufficiently built amps have no sonic difference."
There are many different tube amp designs and some think even different tube brands, especially vintage tubes change the sound, a way to tweak the sound.
Again, a very technically naive statement - none of this discussion is about tubed amps.
Even if you think the design and parts selection doesn't impact SQ, what about the different SS types?
I keep telling people who are so poorly informed that this is not about what I think, it is about what one observes if one makes careful observations.
post #214 of 540
No what is being lost seems to be the truth. You make up ridiculous statements and then you argue with them. The following is one of your made-up statements:
Nobody is saying that all receivers sound the same.
The above is a statement that you made up and that I have repeatedly said is not my position. Yet you repeat it again and again.
post #215 of 540
Originally Posted by runnin' View Post
Post of the day. I don't know why people get so hung up about this, it's supposed to be fun, but then egos get involved.
BTW, I just bought an old Sansui receiver because I was curious about what they did back in the day, vintage early 70's. I can't believe how good it sounds, a better soundstage and all the instruments sound more live than my flagship Onkyo TX SR876 in pure 2 channel mode. The difference is not subtle and I still can't believe it.
I think Sansui, Nakamichi, and some of the older Pioneers sound truly astonishing. They may not be as "cool" as modern receivers and they may not have much in the way of features but that sound quality, so amazing! That is what this is all about, egos and thinking you know better than others. Instead of giving me good counter arguments, I am getting taught definitions and told I do not know what I am talking about. That shows me I struck a chord and they are having issues proving me wrong. The thing that kills me the most is Arny changes his view on this matter repeatedly, if he could pick one view and keep it.
In truth, we are free to believe what we all want. If you think all amps sound the same, goodluck with that. I just know for a fact it is impossible because there is way too many variables, too much difference in amp performance, and too much faith in biased tests. I wish all amps sounded the same, I would have bought a $200 Denon or Pioneer and called it a day, saving me $800 for speakers or some really nice other things.
Edited by Ricsim78 - 2/8/13 at 12:07pm
post #216 of 540
The good news is that what you think is not of the essence.
One of your problems is that you appear to be very poorly informed.
ABX tests are an industry standard kind of listening test that is widely used for developing audio products and has been used widely for about 40 years. That you do not know this is an indication that you are not keeping up with modern audio technology.
However, ABX tests are not the be-all and end all of listening tests. If you were actually just keeping up with even just the documents cited in this thread you would know that other kinds of blind listening tests are also used, such as a test mentioned in an industry standard that I have cited being ITU recommendation BS 1116-1. You obviously never read it, or perhaps it was written at a grade level that is beyond your reading comprehension.
That argument is not uncommon, but you have to realize that it is self-defeating. If ABX tests aren't realistic, then neither are just about any other kind of listening test. They all change the nature of the listening experience from the unfettered experience of enjoyment and pleasure to an experience that is composed of analysis and dissection of the sound.
Since the full potential of a modern AVR includes equalizers and automated frequency response and timing adjustment facilities such as Audyssey, MCACC and YPAO and that the reason for the existence of these facilities is making audible changes, then your statement has to be true.
You see, you again appear to be arguing with yourself!
post #217 of 540
As I said, your running out of materials champ. Your not shooting me down or proving me wrong, your desperate to shut me up because I am not a advocate of yours like Kbarnes. What you say is also not of the essence either because what you say changes constantly. What I say must be striking a nerve because you have mutli quoted me this entire time.
Let us agree to disagree, if you agree with me and I am arguing with myself them quit arguing with me. biggrin.gif
There are lots of listening tests out there, that have been "industry standard". I do not agree with ABX test methods, and yes I have read of them before but I do not need to read articles when I can simply hook up a receiver and hear for myself. What good are test results (inconclusive ones at that) when my hearing, as limited as it may be, is the final critic?
Your trying too hard to seem smart to make sense or have a place you stand on this matter.
post #218 of 540
Sugar pills cured my arthritic shoulder (bicycling injury). Prove me wrong.
post #219 of 540
[*] ABX tests are inconclusive
False claim. ABX tests and other comparable kinds of DBTs have been the audio industry standard for about 35 years. Being unaware of this dates you.
[*] ABX tests have nothing to do with real world listening,
Nothing is a very strong word. In a situation like this it appears to be childish hyperbole.
you won't always be running your AV receiver in direct mode
People speak here of doing that quite frequently.
and you will not be level matching it (what would you level match it to?)
You seem to have missed the point that listening at different levels is a very obvious audible difference. Why would one compare audio gear when each piece being compared is running at a different level?
You seem to have made a giant stumbling block out of something that seems quite obvious and simple. This seems to indicate a giant lack of practical understanding about how we hear things and why.
[*] ABX tests seem to be 50/50. You cannot say people were just guessing because the same amount chose correctly as opposed to not.
This sort of naive statement suggests a complete lack of understanding of how to run a test and statistical analysis.
[*] If the ABX test is on the skeptic side, it is a useless test because it is biased towards the skeptic. Saying, "the people correct just guessed" is assuming and siding with the skeptic.
One of the essence of science is skepticism. Another statement that any well-informed person will dismiss as coming from a very naive background.
[*] If you do not have real good headphones or equipment, I am sure you may not be able to hear the difference between components.
Another naive statement that does not recognize that in general ABX and other listening tests are performed using the same speakers and headphones as people use for listening, including widely-respeded and high end products.
[*] Running an amp in direct mode will make the amps sound similar, I never disputed that and it is a fact. You are basically bypassing the components that make them different to begin with.
Running in direct mode is a distraction. First off, a lot of people seem to be saying they do it. On the other hand there's no problem with running with the DSP in the signal path as long as it is not adjusted to create an obvious audible difference such as enabling an equalizer that has non-flat settings.
[*] I know no one who always runs their receiver in direct mode (I never do)
It has already been established that you are not the source of all knowlege to say the least.
[*] Actually, as a stereo only receiver, the Sansui sounds better in general.
Opinion stated as fact. Which Sansui receiver of the dozens of models made is not stated. Obviously a Red Herring.
But there is no DAC, no surround sound, no DSP, no speaker distance settings, just bass and treble controls. I can set my Pioneer to sound similar but I need to really tweak it.
I have no problem with comparing receivers with the DAC and DSP in the signal path. it appears that you are back-tracking because in earlier posts you said that every part and every power amp affects sound quality. Plenty of those are in the audio path when the receiver is in direct mode. If you don't know that, this is just another example of your confusion about how audio gear works.
[*] You can knock my methodology and I can knock yours or counter, but you will never change my opinion
I fully understand that.
It is quite clear that you are very poorly informed about audio technology. You appear to be an unstable person who keeps changing his story. You make up arguments and then your argue with yourself. You appear to incapable of reading technical articles written at an normal adult level and properly summarizing what you have read. Some of your posts are full of insults to others while you rant and rave about presumed insults to yourself that are merely description of your apparently confused mental state. Your understanding of audio does not appear to include recognition of major developments of the past 40 years.
post #220 of 540
Oh arny, just stop. It's enough of your babyish argument.
Just another example of the futility of trying to have an intelligent conversation with this person.
post #221 of 540
ABX tests are neat, bravo for such a feat. But the fact they are unrealistic takes them out of the equation because we live, and hear, in reality. Bottom line, you say they make common sense of things but to me they just compound the problem and are biased towards audio difference skeptics. That in itself makes them useless and no indication of exactly what they are trying to prove (the fact there is a goal to prove people wrong about audio differences make them not a test, but an attempt to prove a view or point.)
So forget about them, as far as this argument goes. We are not doing tests, we are opening our receiver boxes, settings them up, and using them.
Intelligent in your eyes is someone who agrees with you and does not question you. If we do not agree, we are wrong and are "schooled" by you but your school sucks!
My responses are intelligent because while you are trying to show everyone I have no idea what I am doing, my whole argument is being largely ignored by you. In place are multi-quotes with little jabs about me. Like I said, pathetic. That and the fact you are not even clear on this issue where you stand with it because it constantly changes. Multi-quoting me and trying to use big words is no indication of intelligence or merit. As I said, you are failing and you are lost in your own views.
Oh and I just read your multi quote monstrosity above, lol at you. You say I am unstable but everything I have said has remained consistent while your views are constantly changing? Hypocritical much?
ABX tests are important to you and meaningless to me, as for you saying I have no knowledge of audio, I can say the same about you. But instead I will just be the bigger one and await for you to prove what I said wrong. I been waiting this whole time and instead all you can do is sorry attempts at insults.
Next?
Edited by Ricsim78 - 2/8/13 at 12:51pm
post #222 of 540
Members, try to refrain from posting insults or you will be removed.
K
post #223 of 540
I don't understand your attitude towards a test methodology, one which is designed to ferret out whether or not there are actual, humanly-recognizable differences between two things. An ABX test has the purpose of overriding preconceived notions in the minds of the participants, and determing whether or not they can accurately distinguish between two different things.
A properly designed test is only biased against unsupported assertions and unfounded beliefs. To many of us, this is a valuable function.
post #224 of 540
Arny you like picking on me, must mean you like me! I think my next project will be to buy an AVR with Audyssey and see if it improves my two channel performance. It seems this route is most popular here.
Any recommendations for an AVR that is sufficient? Speakers are Vapor Audio Cirrus and using a Rel sub. I think the speakers are rated at 87db.
post #225 of 540
Well, you've got a sub which says good things about you. ;-)
I don't have any specific recommendations, except it appears that the top of the line Audyssey system is Audyssey Multieq XT 32. Maybe someone will chime in if there is additional alphabet soup you need to be aware of.
Remember me? I'm the guy who thinks that good receivers tend to sound pretty much alike so how could I get very specific about recommendations? ;-)
post #226 of 540
Any medicine that helps you is good medicine. Be more careful next time?
post #227 of 540
To me, tests prove nothing about your actual experience. Just like crash tests for a car, it is good to know my Grand Prix GXP is decent in crash tests but it was not my reason for picking the car.
If you feel tests are useful, and I feel they are too but certain tests like ABX tell me nothing useful that would sway me to buy a product over another, then use them to influence you. That is your right and I will not tell you that you are wrong.
post #228 of 540
What accounts for that then?  Different electricity in the other room?
In every ABX test the receivers are used to their full potential. What made you think otherwise?  Is it because you don't understand what level matching is?
This is so wrong that I wonder if you are serious or if you are having fun with us?  Half could NOT pick out the difference. Half said A was 'the one' and the other half said B was 'the one'. That is the same as random chance. For there to be any meaningful result you would have to have, say, 80% picking A every time and only 20% picking B. This means it cannot just be random chance at work, but a real and discernible difference. You are assuming in advance that there is a difference - A being better than B - and that 50% of the audience could detect it. That isn't how it works - you need to bone up on statistical probabilities. What, for example, if there is NO difference at all - say Amp A and Amp B are identical units?  The result is still 50-50. It is called 'guessing'.
Unfortunately, because you keep repeating this, it also damages your credibility wrt to everything else you say (if you are for real on this).
When you;ve read up on statistical probability theory, come back and tell us you now get it - a 50-50 spilt is random guessing.
Edited by kbarnes701 - 2/8/13 at 1:57pm
post #229 of 540
I'm not an 'advocate' of Arny's and I am sure he doesn't need one. I am an advocate of using science to back up my understanding of reality, rather than just constantly saying "it is so because I say it is so and my ears say it is so".
post #230 of 540
And that's got to be difficult, given what appears to be at least one freakishly large ear you have there.
post #231 of 540
I'm not going to debate anymore about this issue. I have made my points and I do not wish to argue or insult people.
post #232 of 540
step right up. I gotta million unproven patent meds that you have to have at inflated prices.
Actually, it's pretty unlikely that sugar pills cause in improvement, although an improvement may be experienced when a person takes them. There is, in science and actually also in life a difference between coincidence and causation. It''s kinda the reason for double blind testing in that arena. But if you wanna make PT barnums's progeny rich, knock yourself out
post #233 of 540
Next?
I struggle to understand how an abx test is not in the real world. they aren't conducted in an alternative dimension.
admittedly we are in a difficult to deal with realm here, because most of us will say trust your ears at some point, even if we're talking just about choosing preference over reference. You don't hav to be unintelligent to be human (I hope) and the interferences that double blind testing eliminates are due to the testers and testees being human. nothing more, nothing less.
IIRC, it was you who suggested your receiver would sound different in a different room. If I'm right, use that intelligence to assess whether there may be confounding factors that make assigning the receiver the responsibility for different sound in different rooms a little questionable. the room has so doggone much effect on what the speakers sound like. heck even moving the speakers in the same room has a big effect, readily recognized by any well meaning subjectivist that I ever read and/or bought wholesale. Like I said, at some point you do have to trust your ears, but the sun won't go supernova if you at least apply your intelligence to understanding why there are protocols that have been proven to work in a number of contexts to assess human reactions to various stimuli, whether it's sound systems or medication. From a psychological perspective, I personally find it utterly fascinating that folks eventually determined that double blind testing is necessary even with PnD and MD researchers who are the very soul of rationalism giving the drugs or whatever's being tested. turns out they're human too and give cues that they cannot control because they're subconscious to the test subjects who don't know they've picked up the subconscious cues from the test givers. It's pretty sophisticated stuff that covers the whole of communication among human beings. Not fully understood, not likely ever to be fully under the control fo the communciators because we all continue to have subconscious processes going on that we can't see or control (which is the reason they're called cubconscious). It's actually pretty groovy stuff, at least to me . . .
post #234 of 540
Stop and think about this statement for a bit. What do you think the results would be if you brought together 1000 people and asked them, "I'm thinking of a number between one and two. What number am I thinking of?" Let's say you were thinking of the number 1. In a test that large, you will have 50% of the people say 1 and 50% of the people say 2. Is it reasonable to assume that the 50% that said 1 were able to read your mind? Because that's exactly what you keep trying to argue.
post #235 of 540
+1
post #236 of 540
That is my 'listening ear'. The other, regular sized one is my 'golden ear'. ;) I only use my golden ear when I am auditioning 'high end audiophile' gear.
post #237 of 540
+1. The fact that he doesn't understand this basic point about ABX testing invalidates everything else he has to say on the subject unfortunately (for him).
post #238 of 540
What if during those ABX test they would take the 50% that "guessed" right retest, and if only half of those people guessed right in second test, then this theory would hold water?
post #239 of 540
What if during those ABX test they would take the 50% that "guessed" right retest and if only half of those people guessed right in second test, then this theory would hold water.
It would be just pure chance as it was before.
post #240 of 540
Not if all or most got it right again, then it proves they hear a difference, right? Or to prove something what percentage is needed?
