AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Count 1 more for all receivers sound the same
Count 1 more for all receivers sound the same - Page 9
post #241 of 540
Originally Posted by Todd68 View Post
Not if all or most guessed right again, then it proves they hear a difference, right?
If it's a large enough sample in the first case than only 50% would guess right again. ABX testing has been proven to be very accurate. They have even used audiophiles who have a great deal of listening experience and they were no better than those with next to none.
post #242 of 540
The retest would be more accurate I think. It could be some actually hear a difference even under the stress of the testing procedure.
post #243 of 540
As I said, if the sample size (number of listeners) is large enough then additional testing would have the same result.
post #244 of 540
I would like to see an ABX test of headphone amps. It seems to me, from years of frequent headphone use (Senn HD600 with Asus Xonar Essence STX) that headphones are far more revealing of SQ than even my very good speakers.
post #245 of 540
Just thinking back, I owned a Bryston 4BST and later bought the newer version 4BSST, and the improvement was small, but I swear the highs were a little cleaner. Not much of an upgrade but I heard it , and no way could I tell the difference in a DBT or ABX. Small differences would be hard to pick out in these testing procedures, but doesn't prove they don't exist.
post #246 of 540
It would be just pure chance as it was before.
Not if all or most got it right again, then it proves they hear a difference, right? Or to prove something what percentage is needed?
I am struggling to believe that people don't understand this TBH.
Imagine this:
You go to a test where you are asked to decide which of two tiles is black and which is white. There are 100 people in the audience.  The tester holds up a tile. It is white. He asks for a vote. 100% say that tile A is white. He holds up the next tile. It is black. 100% of people say tile B is black. This is because there is a clear difference between A and B that everyone can see. Repeating the test gives the same result no matter how many trials are made.
Now, go to an amplifier test - same 100 people in the room. The tester plays two amplifiers for you. He doesn't know which is A or which is B (it is a 'blind' test).
He asks if anyone can hear a difference between A and B. 100% of people in the room say they can hear a difference. He plays another amplifier and asks the audience to say if it is A or B. (They just listened to both remember and said they can identify A from B). Some people say it is A and some say it is B. Someone (or a computer) makes a note of the number of people who say it is A and the number who say it is B.
He then plays another amplifier (he doesn't know which it is remember) and he asks the audience if it is A or B. Again, some say it is B and some say it is A. Note that it is not necessarily the same people who said A or B before.
He then plays another amplifier and asks if it is A or B. Nobody knows at this stage which is is (blind test right?) - it might be A or B. Again, some people say it is A and some say it is B.
Sometimes, because of the random selection of A or B, B is played 4 times in a row, say. People are asked which it is each time. Some say it is A and some say it is B. This goes on for a while and then test is finally over.
At the end of the test, the scorekeeper reveals the results. The first test the amp playing was A. Roughly 50 people said it was A and roughly 50 said it was B.
The second test the amp playing was A again. Roughly 50 people said it was A and roughly 50 said it was B. Note these are not the SAME people each time who are saying "it is A" or "it is B". It is just 50 people.
The third test the amp playing was B. Again 50 say it is A and 50 say it is B.
This pattern is repeated for all the tests. What conclusion can we draw?  The answer is that we have to conclude that nobody could reliably tell A from B. If they could have, just as with the black and white tile test, a very high number would consistently get it right.
If A was definitely different to B (say they believed it had a 'warmer' sound) then they would identify that warmer sound most of the time - so the scores would be more like 80% against 20% each time. The fact that the scores were more like 50% against 50% each time shows that people cannot reliably tell A from B. IOW, if people hadn't even tried to tell one from the other and had just picked A or B each time, at random, you would still get roughly 50% picking A and 50% picking B. That is the probability when there are only two choices, just like if you toss a coin 100 times, it will come down heads roughly 50 times and tails roughly 50 times (try it and see).
I hope this has helped explain it.
post #247 of 540
Imagine this:
You are more patient than I.
post #248 of 540
With headphones, the room has been removed from the equation.  That is where the real difference is, rather than the difference between one amp and another.
I know nothing about headphone amps BTW, but assume that that they have reached a stage, like other amps, where there is little to choose, SQ-wise, between them. It would be interesting, as you say, to see a blind ABX test of headphone amps. Removing the influence of the room should make it easier to hear the differences, if there are differences.
post #249 of 540
It's the last time I promise you :)
post #250 of 540
I can detect a large difference between the amp built into my computer's motherboard and the Asus Xonar Essence STX headphone card. They both have circuitry that is said to have less than 0.1% distortion, signal noise ratio greater than 100db, and flat frequency response. I can hear this difference whether I'm using $100 Senn "ear buds" or my Senn HD600. What I've read has convinced me that the Realtek audio circuitry on my motherboard does not actually meet it's specs. Sometimes one cannot rely on manufacturer specifications as they are affected by the marketing department. Not that any of this is applicable to the title of this thread.
Edited by Theresa - 2/9/13 at 6:32am
post #251 of 540
That depends on the on the statistical confidence level you're looking to achieve. Did you take any statistics courses in your younger years?
post #252 of 540
Thanks for explaining the testing procedure. But the test could be repeated comparing a different pair of amps, say that old SAE I had and my current mono blocks, and the outcome would be different. If the speakers used are not capable of high resolution and set up optimal, the differences would be hard to detect. If a mid level AVR compared to my mono blocks would not prove all sufficient amps do not sound the same, I would be surprised to say the least.
Anyway, at least I learned something today!
post #253 of 540
So....on another note, which came first, the chicken or the egg? This is a classic discussion about audio that I think will change few minds but give some a chance to show us their knowledge.An amp is not an avr, amps may or may not sound enough different for 99% people to hear. An avr has a lot of different things going on, mostly the preamp implimentation, and YES they sound different. A lowly Denon don't sound like a midgrade HK( to me) regardless of what anyone thinks.I have owned plenty of each over the years and keep them based on sound, not name. The HK's have always won any sound comparison between Denon, Onkyo and run of the mill,( sometimes even priced 3x more) avrs for musical presentation.
I 'd love to have a $200 avr sound like a $3k avr, but it just don't. That said, I currently have no HK but several others that cost more but don't compare for sound.I really miss the great HK sound which was better with no correction than my $1k plus units with the best correction available in an avr.The only reason I don't have an HK is I sold it for much more than I paid for it.Everyone believe what you will, it's human nature, it's all good if you're satisfied.
post #254 of 540
Based on what sort of testing?
What I've read has convinced me that the Realtek audio circuitry on my motherboard does not actually meet it's specs. One cannot rely on manufacturer specifications as they are affected by the marketing department. Not that any of this is applicable to the title of this thread.
The Audio Rightmark program is easy to use and pretty much tells all.
It is possible that one or both of these headphone amps has a high source impedance, which shows up if you measure frequency response with the headphones attached. Headphone amps are one component that can show tremendous difference in measured frequency response between measurements with and without a real-world load. Speakers and good amplifiers are far more consistent, but these headphone amps and headphone jacks on AVRs are all over the map.
post #255 of 540
What would be your explanation for the findings published in the article Arny linked to, here:
http://webpages.charter.net/fryguy/Amp_Sound.pdf
I know this post is from several pages back, but I wanted to point out a few issues I have with their testing procedure:
1. The sample size is laughably small (25)
2. They intentionally brought in people with preconceived biases (never good for a so-called "scientific" test)
3. Their testing methods were inconsistent (ABX vs pulling wires to switch between amps)
Although their results are interesting, I would hardly call this a rock solid scientific test. All that it tells me is that further testing is needed/warranted.
The results may not be any different in a "real" scientific study, but the testing procedures followed in this particular article are pretty poor IMO.
post #256 of 540
Originally Posted by JHAz View Post
Sugar pills cured my arthritic shoulder (bicycling injury). Prove me wrong.
Never underestimate the power of the human body in repairing itself. The brain is not well understood yet and it is quite possible that simply willing yourself better (when you honestly believe it will happen) works. Sugar Pills are simply a way to make this happen, as you then believe it is the pill making you better, which allows you to honestly believe you will get better, which then allows the brain to make the body heal itself. The human body really is an amazing thing.
That said, if someone thinks something sounds better, then (to them) it DOES sound better regardless of whether it really IS better or not. Perception is reality, and if someone is happier with their belief then I say we should let them keep it (provided they neither force it onto others and provided it does them no harm).
post #257 of 540
Originally Posted by Ricsim78 View Post
ABX tests are neat, bravo for such a feat. But the fact they are unrealistic takes them out of the equation because we live, and hear, in reality. Bottom line, you say they make common sense of things but to me they just compound the problem and are biased towards audio difference skeptics. That in itself makes them useless and no indication of exactly what they are trying to prove (the fact there is a goal to prove people wrong about audio differences make them not a test, but an attempt to prove a view or point.)
So forget about them, as far as this argument goes. We are not doing tests, we are opening our receiver boxes, settings them up, and using them.
Intelligent in your eyes is someone who agrees with you and does not question you. If we do not agree, we are wrong and are "schooled" by you but your school sucks!
Great post, in the real world people need to quit taking themselves so seriously and examine how their love for audio became some kind of crusade.
post #258 of 540
It's not the love of audio... rather the endless desire to lecture and all of what that entails... in their mind. The simplistic theory simply gives them a platform to stand on and disregard the real world.
post #259 of 540
Wait, you wrote "perception is reality". But you contradicted that claim in your prior sentence, when you suggested a person might think something sounds better, regardless if "it really is better or not". If we each make reality, then why do you refer to a reality outside the individual's perception?
Also, you wrote "if someone is happier with their belief then I say we should let them keep it". I don't know what you mean by "let them keep it". Of course a person can hold any belief desired - it is not a matter of letting the person hold a belief. But once a person puts a belief out into the world, then the belief is open to review and critique. For example, if in the face of the reasoned argument and evidence presented by Arnyk, the commenter Ricsim78 wishes to continue with a poorly thought out and ill supported belief, Ricism78 is free to do that. He just shouldn't expect anyone to take his belief seriously. Too often a person will desire to not only hold a belief, but also desire to put the belief out into the world, have the belief respected, and have the belief shielded from critique. That is not how it works.
This has been one of the most bizarre threads I have come across at AVS Forum. Which means it has also been one of the most entertaining to read, lol. I give Arnyk a lot of credit for sticking with well thought out and reasoned argument, in the face of some ill-conceived and poorly thought out responses. As suggested, some people do not understand science or evidence based decision making. In an earlier comment "religion" was mentioned. It is uncanny how closely this discussion parallels typical discussions involving religion, including the idea of holding a belief regardless of, or even in spite of credible evidence the idea is not worth holding. At one point, the commenter Ricism78 even indicated nothing could change his opinion. What an unfortunate way to operate - doomed to hold a position regardless of any reason or evidence to the contrary.
post #260 of 540
There is a saying, "don't throw your pearls before swine." In other words, rational argument in this case is wasted on people who don't even acknowledge the value of rationalism.
post #261 of 540
You are very welcome.
Yes, I agree that the outcome could be different. It's just that, in all the dozens of reports of AB tests I have read, it never is. They have all been inconclusive and come in at or around the same result that random chance gives.  I think you would be surprised if you could ABX your monoblocks against the AVR amps, so long as the latter are working to spec and not clipping and are able to drive your speakers correctly (ie they can handle a 4 ohm load if you have 4 ohm speakers, or a difficult load as presented by some 'audiophile' brands).
I am not sure if I wish this was different and that all amps sound different to each other, or if I am happy in the knowledge that they don't. If the former, I could know that I would get an improvement in SQ by spending more on a 'super amp'. If the latter, I am happy to know that I don't need anything other than my Emotiva amps because nothing else will give me a sonic improvement.
At the end of the day, it doesn't really matter much because I know that the real way to get BIG improvements in SQ is to get really, really good speakers (which I believe I have done) and really, really good subs (which I have definitely done) and concentrate on measuring and treating the room. Especially the latter as it is so cheap, comparatively, to do. That is where the real changes will be heard - not in modern electronics.
post #262 of 540
There are dozens of similar tests all over the net - I posted a link to about 50 recently in this thread. They all come to broadly the same conclusion - nobody can reliably detect a difference between the amps under test. Some tests may have flaws, but not all of them.
Incidentally, sample size in a survey isn't all that important so long as the sample is representative of the whole. That's why polling companies can predict elections etc very accurately by surveying 1000 people, even though the universe is over 100 million (in the US).
Incidentally again :) - that the audience had preconceived biases helps the test's validity not harms it. Even with their bias or predeliction to prove that amp A is different to amp B, they still couldn't reliably hear any differences.
post #263 of 540
It's neither in my case. It's a genuine desire to help people via the medium of these forums, in the same way that I have been helped so much by them in the past. It's called "giving something back".  Of course, everyone is entitled to their views and beliefs and I have never said differently. The real issue is that you will find people on these threads who will pass of their opinions as facts. So they say things like "All amps sound different to each other and I know that for a fact because I can hear the differences with my own ears".
Now this is not only wrong, but it doesn’t even enter the arena of sensible discussion because someone's opinion is just that - an opinion. It's like me saying that "I know all French people smell of garlic because I have smelled it with my own nose". People who say these things will never offer any objective evidence to support their position (usually because there isn't any) and will just repeat, ad infinitum, that it must be so because their ears say so. Worse, when presented with objective evidence that they are wrong, they will refuse to accept it and cling to their original position regardless. Even to the extent of saying "You will never convince me otherwise". IOW, their mind is made up that they must be correct n matter what.
Why does this matter? Because for every person who contributes to a thread, there are many more who silently read it. And many of them are looking for information to help them with their purchasing decisions. And many of them are on tight budgets. And many of them have very little knowledge of audio or acoustic science. So when they read statements that tell them that one of the most important things they can do to improve their SQ is to buy a new amp, many of them will go out and do that. They will do this even though it is almost always a waste of their money and they would benefit far more from rearranging their rooms or adding some simple room treatments, at very low cost if they are made on a DIY basis (which is very easy). So I, personally, think it is important to provide the right information, backed by objective science, in order to provide a counter-perspective. Hopefully, some people will read this and think "hmm, maybe that $2,000 amp would be a waste of money after all" and they might investigate other ways which have been objectively proven to yield what they are after: better SQ.
So I, personally, do object to being told I am on a "crusade" or have "an endless desire to lecture others" because neither position is remotely true and you can verify my aims and intents on AVS by searching my posts, especially in the Audyssey thread where I usually hang out. To offer objective, evidence-backed views is not disregarding the "real world" in any way IMO. It is very much trying to help one of the most 'real world' issues there is: spending one's hard-earned cash wisely.
post #264 of 540
+1
post #265 of 540
+1
+2
post #266 of 540
I wasn't responding or talking to you, so I'm puzzled as to why you think I was telling you you're on a crusade, etc. If I want to do so, I will use the quote feature, or address you by name. I have no interest regarding your intents here nor reseaching your posts. There are, however, those who take your position in the matter who are on a crusade, if you want to defend them perhaps you could get some of their quotes and defend them directly.
You yourself told me earlier this week that you get tired of repeating yourself, and yet here you are once again doing so. Using a strawman argument, like the suggestion that the most important things one can do to improve SQ is a new amp, only weakens your position, I've never said that nor seen it expressed here.
post #267 of 540
This is outstanding. Thank you.
post #268 of 540
Lots of small-scaled, amateurish and negative trials don't add up to prove anything conclusive, only suggest a trend. For professionally conducted studies that are negative or a mixture of positives and negatives or inconclusive there are methods (meta-analysis) to evaluate them as a larger group to look for hidden positives.
Sample size IS important in statistics. Small differences that are statistically non-significant might become significant in a larger sample size, because the sample size is factored in determining the p value. You only have to read some clinical trials to see what sort of numbers (hundreds and thousands) are involved and the differences are often very small, not 80% vs. 20%, this large magnitude of difference doesn't happen. Usually when the sample size is down to 10 or 20 very very few studies have statistically significant results. Also note that 20 people each doing 10 trials isn't the same as 200 doing 1 trial in statistics.
As I said before some of you just use small and amateurish trials as concrete proof and this is not how proper science works in real. I'm not against DBTs but just the way you over-interpret their true meaning and significance. If you think some of these audio trials are well run you might also want to read some of the large scale clinical trials or studies (some are freely available) to get some idea of what's it all about at that level.
Edited by Kilian.ca - 2/9/13 at 7:17pm
post #269 of 540
I thought everyone understood that phrase, I am sorry for my assumption. The phrase "perception is reality" does not mean what you think it does, it simply means that people say something is real and true if they believe it is real and true, regardless of the actual realness or trueness of the item. For example, a rumor starts that a man who just moved into town is a pedophile child rapist who just got out of prison. The man finds himself ostracized by those in the town and has no idea why. He is not actually a pedophile and was never in prison. That does not matter, for the damage is done. Perception is reality. You see it used to great effect in politics, the current attempt to ban specific types of guns and magazines due to a tragedy even though the ban would not have done anything to prevent the tragedy...but perception is reality and many people feel the ban would have prevented it even though the view is not true.
Taking a snippet out of context and then arguing against it using the part you did not copy is silly. You purposefully copied only half my sentence and then argued against the sentence using the half you did not copy. Here is the part you did not copy: "(provided they neither force it onto others and provided it does them no harm)." Keeping the sentence intact is quite useful, I recommend doing it.
"let them keep it" means "do not start a holy crusade to tell someone they do not hear what they say they hear and that the improvements they currently enjoy do not exist". Why go through the trouble and work to make someone less happy? If someone is happy with what they have, if they claim it sounds better to them, then just believe them and be happy for them too. Why fight to tell them they certainly cannot be happy and they definitely do not hear an improvement? Not saying you personally are doing this, just answering your question.
My personal view is that, divorced of all the extras that make each AVR different from one another, they all sound the same. It is the post processing that makes them different, makes one sound better to some (and worse to others) than another one. Audyssey vs MCACC, DSX vs NEO:X, etc. That is why we buy the AVR in the first place, not because the electrons flow through the copper the same way on all the AVRs built, but because some of them use better correction and alteration techniques than others do. But if it makes someone happy to feel their new AVR sounds better than their old one (both without any post processing), then I am happy for them too, regardless of my view of it.
Religion is a good comparison. Many atheists feel the need to tell theists they must stop being happy while serving their god...that since the god does not exist their happiness is fake and must be thrown out. I say the best atheists are those who are happy for the theist - happy that the theist has found happiness in their belief.
Just my two cents.
post #270 of 540
Treating the room is something almost no one does - heck, before I started building my dedicated theater room I never even knew rooms SHOULD be treated. It definitely does give you a great bang for the buck.
