Originally Posted by Schroinx
... What should I setup in windows or codecs etc to ensure that the amp only get a format it can understand and any transcoding takes place on the mini? I can get a used 2012 Mac mini with 2,3ghz i5 and 2gb ram for 75% of the price for a new 2,5ghz/4gb. Would I notice/need the faster CPU/more ram?
Does the Mac remote work with windows/media center?
You would set that up in your settings. Most likely in the OS and playback software. I have a reciever that predates HDMI and HD audio. I told windows to use a digital audio drivers which handles sounds for in the OS and web videos through a browser. Had to tell Media Center and Plex the kind of audio setup I had.
Transcoding can be intensive, but unless you're doing video, your most likely fine if it's just the audio. And you're probably fine even with the video unless it's a really high bit rate video and HD audio. I've played full 1080p HD audio MKV rips from MakeMKV ok; some buffer at the beginning of the movie, but played fine the rest of the time, at least through Plex. I found it improved when I told Plex to play through HDMI, yet I have no HDMI audio nor does the late 2009 mini even have the hardware to support HDMI audio. I think it's just playing the core 5.1 DD or DTS track.
