If there's one thing I've learned over the past couple of years with our 32" Aquos TV/computer monitor and DIY HD antenna, it is that OTA HD PQ beats satellite HD hands down, and can even approach that of a good BD movie.
Because my wife and I will continue to view our local OTA HD stations, I want whatever 65" TV we now buy to have a good tuner and a good ADC that will put an image on the screen that is every bit as good as the signal it recieves.
Are all TV tuners and A to D coverters created equally and, if not, which manufactuers have the highest quality hadware and software components in this regard?
This used to be an important consideration when buying tube-type TVs. For those of us who want to capture and display present-day OTA signals, it still is.
). Reception has continued to be flawless with the LG but again, I think any LG, Panasonic, Samsung, or Sony would be fine.
This rather crude-looking device works great from inside the house!
The differences are that you mounted your bent wires to blocks which are in turn mounted to a metal tube, and put some additional wire mesh on the back. What does the wire mesh do? Does it somehow concentrate the signal as a dish would? Does it eliminate background interference?
