Hey all, I'm new here. I'm hoping some of you guys can help me with a problem I'm having.
I'm trying to connect an older Xbox 360 with only component video for HD outputs to a Pioneer receiver. The receiver connects to a projector via HDMI. I've tried plugging in to all 3 component video inputs on the receiver and assigning it under DVD on the input setup. I get audio just fine but video never works, including trying to turn video conversion on and off. I've flipped over to standard 480p (through composite) and set the HD resolution to 1080i but that didn't fix it either (unless that doesn't actually set the HD resolution properly?). I'm starting to run low on ideas and sorry if this isn't exactly the right section. Thanks!
