I have to warn that I am new to media streaming devices and HTPC. I have done much research but I want to make sure the gaps in my knowledge don't lead me to buy something that won't work for my purposes is overly expensive for features I don't require.
I am looking for a device or devices (cheapest option) to stream my HD movie collection to multiple tv's in the house; some of which (TV's) are 2005-2008 composite connection and one of which is HDMI. I don't have internet nor do I plan on getting it any time soon so streaming internet content is not really a concern. I have read about video game streaming or emulators, which I am interested in but is not really a primary concern. Also I don't really want to have to run cable so a wifi capable system is a requirement. I also feel I should mention that I would like each television to be able to play a different movie or media file on one tv and another on the other, at the same time. I do own a mac and all files will be moved from that machine onto the device so it must be able to work with mac. Other than that I have listed some specifics below.
Must be able to (or support):
-work with Apple or "mac" files
- WIFI
- As many file types as possible (mkv, avi, mpg.....subs)
- Able to connect via hdmi as well as composite
-Something with HD space included (at least 2TB)
- Audio streaming
-Allows for up to 4-6 TV connections
- Is reliable and stays updated
- Able to handle 1080p
-Easy to use and setup
I can't really think of anything else but if I do I will let you know. I figure it should be simple enough since I am eliminating the need for internet streaming but I don't want to mistakingly buy the wrong device. I wan't to do this the cheapest way possible without sacrificing quality and I am unsure as to whether I would require an HTPC or the streaming media player. Also I am a little confused as to what I would have to purchase for each television set to be able to receive the signal from the main device I will be buying (Do I have to buy a bunch of HTPC's or media players for each TV i want to access content on or just one HTPC, Media streaming device and then another device for each television which I wish to have access to my main library?) I will need to buy this soon so please let me know what you suggest. Thank you!
- WIFI
- Audio streaming
