AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Multiple RaspBerry Pi Airplay Clients for MultiRoom Audio
post #1 of 2
Hi
I have a few airport expresses setup to provide multiroom audio (am transitioning from Squeezeboxes) but am unsatisfied with the power draw (30-40 watts vs 4-5 watts). After looking into other options I found that I could get a group of Raspberry Pi B (with 3.5mm out and 2-3 watts consumption) and hook them into my amplifier , one per room. They have 1-2 distro's that should work (Squeeze plug). I was wondering if anyone else has tried a similar setup and how did it work out?
I would've gone with Apple Tv's but they're digital only and I currently have a Niles 1230 that I'll be using. Is there a digital multichannel amp (Toslink) that can be used w/apple tv?
Is there anything I'm missing as to why this isn't a good idea or any good alternatives I'm missing?
Thanks a bunch
post #2 of 2
Monoprice sells a converter that will take TOSLINK in and output L/R analog audio.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=6884&seq=1&format=2
I used one of these for a while before I got a real A/V receiver. Only issue I had with it was that it had a little high freq noise whenever there was no input signal (e.g. when I turned the source (TV) off but not the amp).
  Back to Forum: Home A/V Distribution
