Hi everyone, I live in the Chicago area and am interested in building my first htpc. My budget is roughly around $1000.00, and wish to have a good strong easy to work and expand on case. Size of the case isn't an issue as long as it's not taller than around 8.5 inches total. Room around it is plenty where it'll be set. Of course I want to be able to throw any movie type at it and maybe occasionally games but not top priority if budget affects that. I'll most probably be hooking it directly to a router but again if budget allows fast wifi would be nice. I'll need at least a BR drive for physical media occasions. Would like to have a second drive incase the need would ever arise but not totally necessary because I could just connect an external drive. So that brings me to I'd like some variety of usb/firwire/, or whatever kind of needed connections in the front or easy access without having to move it. Low noise would be good but if to achieve sufficient power some noise compared to a PS3 or a little less than the original 360 could be tolerated. I would need it to have enough power for video editing or processing since my daily outdated computer is on it's way out. So is my budget enough for my demands for a complete build from start to finish or am I dreaming? Any comments and suggestions or questions to help someone help me are welcome. Oh and I'll probably be installing windows on it for sure but if another os is better for it I'll be ok with dual booting. Thanks
Sent from the next big thing
. Plus on my old rig I've got pinnacle gaming software installed mainly for navigating windows with the xbox 360 controller. So I'll for sure use it on my htpc.
