AVS › AVS Forum › Audio › Receivers, Amps, and Processors › harman kardon 1700 help
post #1 of 23
just hooked this up and when i go to play a blu ray the reciever just says logic 7 and nothing else
even tried to go into the menu and the only options for sound are dts hd neo and dolby pill something
i know it does hd audio cuz there are symbols for dts hd ma and true hd on the reciever
ps3 is sending a bitstream signal
even my dvd player stuff says logic 7 instead of dd 5.1
please help
post #2 of 23
how are your devices connected? HDMI?
logic 7, dolby pl2 and neo:6 all take 2 channel sources and convert to simulated 5.1
what make and model is your dvd player?
Is your PS3 the slim model or the older fat model?
post #3 of 23
hdmi
oppo 981hd
slim
its only a 2.0 setup for me also but does that mean i dont get hd audio cuz i had a denon that i returned that showed dts hd ma and true hd fine
post #4 of 23
Don't have that receiver so can't say for sure.
Set your surrounds speakers to ON or SMALL whatever the HK calls them and see what happens.
If all of a sudden you get DTS-MA or TRUEHD you have your answer.
post #5 of 23
there is no small or large setting i can find
seems like this harman kardon was a giant ripoff since it doesnt do anything except logic 7
post #6 of 23
Just bought the same receiver and it was doing the same until I changed from PCM to bitstream on the ps3. Fairly new to all this but I'd almost bet it's because you're only running 2 speakers. The denon might have shown dts or whatever but without the 5.1 setup you weren't getting the sound anyway. If what I've read is right about all that you're probably getting better sound with the logic 7 setting anyway, since the dts hd ma is a 5.1 speaker mix. Again though I'm new so I could be wrong
post #7 of 23
can anyone confirm this?
other thing that is bothering me is that the volume is so variable
i watch a linear pcm 2.0 track and the sound is so loud i gotta go to -20db and then i turn on regular tv and i gotta go to like +5db to get the sound i like
thinking about exchanging this and going to a denon 1613 but im not so sure
never had any of these problems with my sony soundbar
post #8 of 23
so finally i figured this out and got it too show the proper codec
its still bothering me though that this reciever has like no customization at all
my speakers are 4 ohms and there is no setting on that at all, im worried i could blow out my speakers
post #9 of 23
Even with AVRs that have a 4ohm setting, it's generally suggested to leave it at either 6-ohm or 8-ohm as the 4-ohm setting simply limits the current flow. The unit will shut down in protection mode if there is too much current drawn by the speakers. Although note that virtually all AVRs at this lower level (to include the 1613) are not designed to power 4-ohm speakers so a good rule of thumb is to just not raise them above an average TV listening volume or a volume level that doesn't shut down the AVR in protection mode.
post #10 of 23
one more question
in settings i have turned off the surrounds since there is no surrounds but when i turn off the sub setting i get some hissing that will go away if i turn the sub setting on (2.0 setup so there is no sub)
is this bad or should i just leave the sub setting on and forget about it
post #11 of 23
Originally Posted by metsfan1545d View Post
one more question
anyone?
post #12 of 23
anyone?
anyone?
post #13 of 23
post #14 of 23
post #15 of 23
post #16 of 23
post #17 of 23
It is bad.
post #18 of 23
Originally Posted by jdsmoothie View Post
It is bad.
can u elaborate?
post #19 of 23
FWIW, I just picked mine up, while I don't have a PS3, mine seems to have no problem properly playing Dolby Digital/DTS tracks set in the auto surround mode.
Do you have the reciever set to auto surround? That is the biggest thing I don't like about this reciever right now is its lack of "Direct" sound feature. So far everything sounds great, but to me some things sounded better in Pure Direct on my pioneer with any EQ turned off, and some things sounded better with it in auto surround.. so far it doesnt seem to be as drastic as my pioneer 521 K and sounds much better than it with certain movies in which I changed from Direct/Auto and vice versa with the EQ on.
Possible you may have a bad unit?
post #20 of 23
These are my first impressions posted in the harman kardon thread
http://www.avsforum.com/t/1429194/the-new-harman-kardon-avr1700/90#post_22767380
post #21 of 23
Just got a avr-1700 tonight and I noticed the same thing until I hooked up my center channel. I had to unhook the center channel while setting up everything. The sound really sucked with the tv until I hook the center channel back up and then it sounded fine. Don't know how to change any settings as I just got it and will have to look at the online manual. I can tell you as a person that has only had 2.0 channel forever that when I added a center channel a few weeks ago my TV watching experience dramatically changed. I'm hoping to get the same dramatic change when I add surrounds.
A good center channel is nice to have.
post #22 of 23
id get a center channel but i got audioengine p4's which only come in pairs so there is no center channel option for matching
also does anyones volume start at like -30
never seen that before on a reciever, -15 is like the highest i can go before its just too loud
post #23 of 23
You can set the default volume level in the setup menu. That way when you turn it on it will be at whatever level you like.
