I'm using my PS3 and did a calibration with the AVS709HD disc on my Samsung LN52B750. The common contrast setting on this TV seems to be in the high 90s. When using the white clipping pattern with the flashing bars (see below)
http://cache.gawkerassets.com/assets/images/17/2011/11/0c200cfa46cebd5305fcdaf5e27e2c26.jpg
I can set contrast to 100 and all bars remain visible up to 253, but there is a definite pink tint. As the contrast increases much past 92 or so, the red seems to run out. I loaded a 109% white window and kept raising the contrast to determine this. My question is, how important is it if the super white signal (the white above 235) looks pink in that pattern? If that maximum white level in a movie is 235, and it looks ok, does it really matter if the whites higher than 235 look pink?
I finally settled on a contrast setting of 95. On the flashing bar pattern, super white still looks slightly pink, but when I look at a grayscale ramp, I don't see pink (just black, gray and white). Also, the gray step pattern looks good. If I want the super white to lose the pinkish hue in flashing pattern, I have to turn contrast down to 90, and the picture is too dim even with the backlight at 4 (it's about 26 ftL). I'd really prefer not to turn the backlight up past 4 because black levels would probably suffer. With the contrast at 95, and the backlight at 4, I get right around 30 ftL. If I look at the RGB color clipping pattern with contrast at 95, red does clip a little, but it doesn't occur until about 241.
Here's some screen caps from HCFR
