AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Size limit for attachments?? trying to attach 7.6MB REW file saved as zip....also 2kb zip file can't load
Size limit for attachments?? trying to attach 7.6MB REW file saved as zip....also 2kb zip file...
post #1 of 23
Is there a file size limit for attachments??
I used zip to compress a REW file with just 4 measurements from 9.6MB to 7.6MB and get this upload error
I'm trying to have others help me in this thread http://www.avsforum.com/t/1446659/multi-sub-help-diy-triangle-sub-w-dayton-audio-rss460ho-4-18-24-sides-x-34-face-x-32-tall-5-5-cu-ft
Edited by mtbdudex - 12/26/12 at 7:00am
post #2 of 23
I'll have to look, but I'd think zip files would not be an allowed file type.
post #3 of 23
I tried mdat format, got this error.....zip is there
Oops! You're trying to attach a type of file which is not allowed. Supported file types are: bmp, csv, doc, docx, gif, jpg, otf, pdf, png, ppt, pptx, psd, pub, rtf, ttf, txt, xls, xlsx, xml, and zip
post #4 of 23
test zip file attachment...
AVS.zip 11k .zip file
post #5 of 23
So zip files work. When I try your file, I get "The file being uploaded exceeds the maximum file size of 5MB" so that's the issue there.
post #6 of 23
Mike-5MB is that real world practical for our forum?
A basic REW file with only 4 measurements is 9.5MB uncompressed and 7.5MB zipped.
Can the limit be changed to 10MB to allow REW data file uploads?
Sent from my 32GB iPhone4 using Tapatalk
post #7 of 23
I'm sure it's hard-coded on all Huddler platform sites.
I would think just about every seasoned AVS member has several of their own cloud accounts for file storage & distribution.
post #8 of 23
Well chalk it up to a Huddler "std" for taking away some simple upload ability for quick analysis of REW by fellow members, one very important tool for acoustic analysis.
btw, 5MB upload limit seems so.......mid 2000's?
My Google Picasa web albums used to be 1GB limit in 2007, then they up'd it to 2GB, and recently to 5GB limit....all still free.
post #9 of 23
I should hope so. That's pretty much all they're used for. And even they have a 20MB limit per file.
post #10 of 23
Ok Mike, I'd doing subwoofer model in winISD and tried to upload a small 2kb zip file consisting of 1 driver file and 1 project file.
The thread is here http://www.avsforum.com/t/1447724/dayton-releases-more-new-subs/30
here is file being uploaded
here is error message
help - this upload file errors are really frustrating...can't believe all the issues I'm having simply trying to do this....never in 15+ years of web have I had so much trouble
post #11 of 23
As you can see above in post 4, attaching a zip file works. Is it this particular file or are you unable to use any file? This seems to be limited to you as no one else is reporting any issues with this.
post #12 of 23
Mike - I had no problem attaching the exact same zip file to HTS forum, so why can't I simple attach the same zip file @ avs forum?
http://www.hometheatershack.com/forums/diy-subwoofers-general-discussion/63483-dayton-audio-um12-22-12-ultimax-dvc-subwoofer-3.html#post582992
post #13 of 23
HT Plan 2x4 Seats-Riser-acoustics multi-sub.jpg 441k .jpg file
I can attach 441k jpg file
but not the zip version ...got same error message!
post #14 of 23
post #15 of 23
I have no issues attaching your file.
post #16 of 23
Yea - I'm running MacOSX Software Mac OS X Lion 10.7.5 (11G63) and firefox 18
post #17 of 23
Firefox here as well
post #18 of 23
I'm trying safari
post #19 of 23
post #20 of 23
so some issue with firefox 18 and macosX and avsforum??
or on of my firefox add ons causing computability issue?
post #21 of 23
I'm spending too much bandwidth on this......if i need to post a zip file I'll use Safari
post #22 of 23
Run FF in safe mode to rule out add ons.
post #23 of 23
re-start, cleared ff cache/etc..it worked.....
HT Plan 2x4 Seats-Riser-acoustics multi-sub.zip 434k .zip file
case closed
  Back to Forum: Forum Operations Center
