AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › DLNA Server with Image Tag support
post #1 of 4
I am searching for a DLNA media Server software (Windows 7) to serve my Music and Photo Libraries (about 20,000 items each) and limited video.
In particular Im looking to support Tags on Image files (I use Picasa to find People and then create Tags from these written to the EXIF files).
I have been using Media Player 11 but it has great trouble keeping uptodate, doesnt seem to find the right Tags, and is VERY slow
Also tried Serviio but that doesn't support any Tags or Keywords on Images.
What about Plex or Twonky or TVMobili ? Has anyone compared ?
Greatfull for any suggestions !
post #2 of 4
Hi, Did you ever find a solution? Its the holly grail for me and would be interested to see if you have solved the puzzle.
post #3 of 4
You need to say what type of media and exactly what device(s) you are using to play it. Some UPnP/DLNA servers work better than others depending on the UPnP/DLNA client or renderer.
post #4 of 4
I'd say your best bet is to ask on the TVMobili, Mezzmo or Serviio forums for a feature request.
There's a DLNA app for iOS called iMediaShare it ties into your Picasa account, might be worth a try. There is also a UPnP/DLNA plugin for Picasa here, no idea if it works.
