post #1 of 1
$1,500 (USD)
send a PM to take the next step.
For Sale:
Sencore Audio Calibration Suite
Will Ship To: Anywhere
I am selling a complete Sencore Audio Calibration suite. I paid over $5,000 for this brand new. Everything is in PERFECT condition. Included are the following:
Sencore SP 295C
The Sencore SP295 SoundPro is a professional quality audio analyzer that is custom-designed for professional home theater and commercial audio installers. Utilizing the latest DSP technology with powerful FFT analysis, combined with proquality analog audio inputs and outputs, the SP295 SoundPro combines the functions of dozens of audio test instruments in one easyto- use product. It is the only portable audio analyzer that provides all the features neededto optimize speaker placement, calibrate system settings, adjust speaker phasing, equalize room acoustics, and verify system wiring and component setup. In addition to its audio analyzer tests, the SoundPro features a graphical back-lit LCD display, AC or battery power, built-in microphone, and balanced and unbalanced inputs and outputs, making it a must-have item for every home theater or proaudio installer's tool kit.
Features
Properly tune and balance any audio system in minutes with Real Time Analyzer.
Signal Level Meter accurately measures any audio input.
Sound Pressure Level meter to ensure proper level balancing of each speaker.
Built-in Distortion Meter for checking speaker distortion.
Use Energy Time Graph to identity and correct uneven sound dispersion in the room.
Polarity Tester checks speaker and system polarity.
Analyze background noise with Noise Criteria test.
Quick, dynamic Cable Tester finds opens, shorts, or crossed cables.
All the output Test Generator signals you need, in one portable package.
Built-in audio bandwidth digital Sample Scope for signal monitoring.
Sencore DAG 5161
The DAG5161 'SurroundPro' Digital Audio Generator is a handheld multi-channel digital and analog audio generator that provides Stereo 2.0, Dolby 5.1 and DTS 6.1 surround, and PCM digital audio from industry standard outputs for testing audio systems and simplifying acoustic calibrations.
Features:
Surround sound Dolby 5.1 and DTS 6.1 digital audio generator with S/PDIF coaxial and optical (Toslink) outputs
Digital 2-channel Audio PCM generator with selectable data word lengths and clock sample rates for testing consumer and professional digital audio equipment through S/PDIF coaxial & optical (Toslink), and AES/EBU balanced and unbalanced outputs.
Analog 2.0 stereo output generator with independent frequency sine-wave, squarewave, frequency selection 1Hz to 30 kHz.
Audio testing and room acoustic analyzing signals such as variable frequency test tones, pink noise at various bandwidths, and impulse waves.
Simple, fast selection of audio test signals to each or all speakers in a 5.1 or 6.1 system with a turn and push of the selector knob.
Teams with SP295C SoundPro via a serial cable or wireless link for 8 automated A/V receiver/room acoustic calibration tests including: SPL, Speaker Phase, peaker Polarity, LFE & Main Channel RTA Equalization, Reverb Decay Time, Early Reflections, Noise Criteria Testing.
Word Clock Output -Timing reference to lock professional digital audio equipment to the generator's internal digital clock.
Standard 3.5mm Stereo Headphone Output Jack.
Portable, battery operated for on-location audio testing and calibration ease.
Sencore MX-299 Microphone Multiplexer
The MX299 allows you to see one real-time measurement of the overall frequency response of multiple listening positions in a room. The MX299 can easily make room response adjustments, without the time-consuming process of manually averaging measurements at different room locations.
Features:
Accessory for SP295 and SP295C SoundPro
Provides a single, spatially-averaged acoustic input from up to four microphone positions for Real Time Analyzer or Sound Level Meter measurements
Provides a continuously updated average measurement of the overall response of the listening area to allow easy equalization adjustments and average response documentation
Avoids the problem of making room adjustments based on the acoustic response of just a single point in the room or of manually averaging measurements to determine needed adjustments
Performs four microphone multiplexed sampling, as used by all major cinema/home theater organizations, for a good average of overall room response
Measure the averaged output of two, three, or four attached microphones, or monitor individual microphones for gain equalization
Internal microphone supply voltages and preamps eliminate the need for extra boxes and simplifies setup
Portable, battery-operated design eliminates the need for AC power connections
Unit power automatically controlled by connection to an SP295 SoundPro
Acoustic Calbration Report and Analysis report software
Audio Cables And Computer Connection Cables Needed For Calibration
Platt Locking Hard Rolling Case To Keep Everything Safe.
Price: $1500.00
Serious buyers only.
Contact Ray 818-396-7457
Thanks for looking.
Edited by Rayjr - 12/24/13 at 6:55am
