So I have some Amazon gift cards to spend and need to replace my sub FAST. I had a Sony SA-WM40 which was great but I gave it to my brother who just put together his first HT setup
So...in it's place is a total POS RCA that was part of a HTIB that I had stuffed away in a closet. I wanted to build but my time frame and the fact that it's about 10 degrees outside right now may have ruined that.
Use will primarily be movies. Remaining setup is Yamaha RX-V2700 receiver, older Infinity two way towers, B&W CC3 center. Room is approximately 15x30 with a large opening to another area.
Budget is probably $500 max and I need to be able to purchase from Amazon. Here are a few I quickly found:
http://www.amazon.com/JBL-600-watt-Performance-Subwoofer-Amplifier/dp/B000FZ1FRC
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_3?s=aht&ie=UTF8&qid=1356535090&sr=1-3
http://www.amazon.com/Klipsch-RW12D-12-inch-Reference-Subwoofer/dp/B000UVWIO0/ref=sr_1_20?s=aht&ie=UTF8&qid=1356534739&sr=1-20
So...in it's place is a total POS RCA that was part of a HTIB that I had stuffed away in a closet. I wanted to build but my time frame and the fact that it's about 10 degrees outside right now may have ruined that.Use will primarily be movies. Remaining setup is Yamaha RX-V2700 receiver, older Infinity two way towers, B&W CC3 center. Room is approximately 15x30 with a large opening to another area.
