I'm having some strange problems getting internet functions to work on my Marantz.
Basically all of the LAN functions work perfectly. Airplay, IP Control etc work without problems. Anything that would go outside of my LAN (WAN) do not function at all. Trying to upgrade firmware freezes the unit to the point I have to pull the power cord to shut it off.
I have set a static as well as DHCP assigned IP and functionality is the exact same.
Has anyone seen or heard of similar issues? I have it hooked up via switch to my Xfinity eMTA.
I have my Panasonic ST50 plugged in the same switch and everything works without issue.
